07-29-2010, 11:51 AM | #1 |
converting to 5 lug, problems with rear and driveshaft
I have a 63 Longbed fleetside, has a 350 with a powerglide behind it. I'm in the process of converting the truck over to a 5 lug, all parts are coming off of a 87 suburban. The rear end is a 10-bolt. The old rear in my truck was a Eaton 8 lug.
I have the new 10 bolt set on the trailing arms, but the problem i'm having is the driveshaft. When I put in the yoke into the tranny, its completely pushed all the way in just to get the rear U-joint to bolt up, and thats even hard to do. This is with the suspension hanging down also. So there's no way at ride height it will work. I'm not sure if the previous owner swapped in a 3/4 or 1 ton driveshaft when he swapped in the Eaton 8 lug rear. The driveshaft itself looks fairly large in diameter. Can someone measure there driveshaft for me? Or does anyone know what the measurements should be for a stock 1/2 ton driveshaft for a longbed truck? I'm thinking about either cutting an inch and a half out of mine, welding it back up, then going to get it re-balanced. Or...getting another driveshaft off of something else that will be the right length. |
07-29-2010, 12:02 PM | #2 |
It's Better With Nitro
Re: converting to 5 lug, problems with rear and driveshaft
It would be best to put the truck at ride height and with all the weight on the tires...then, measure for your driveshaft length. I use a chart similar to this one when measuring for driveshafts in my projects: http://markwilliams.com/driveshaftOrdering.aspx
This way you'll know for sure what the measurement will be for your application - then you can shorten your driveshaft or have a new one made at the precise length for your truck.
07-29-2010, 12:11 PM | #3 |
If you need another correct 2 piece drive line, let me know. (pm) I pulled one out of a 62 3/4 ton. v8 with a 3 speed and a granny gear so you would still have to swap slip yokes
1967custom Last edited by michael bustamante; 07-29-2010 at 12:12 PM. |
07-29-2010, 12:15 PM | #4 |
driveshaft I have now is a one piece. My truck doesn't have a carrier bearing
07-29-2010, 01:30 PM | #5 |
just got done measuring everything. Can someone post up measurements of there 1/2 ton one piece driveshaft for there longbed pickup? I just want to compare and see how much larger this one is. I'm thinking its out of a different truck thats a 3/4 or 1 ton.
From center of u-Joint to center of U-Joint, length is: 67" Length of Yoke that goes into tranny: 3.75" Total length of driveshaft (End of yoke to end of U-Joint) : 73.5" Diameter of Driveshaft is: 11.25" |
07-29-2010, 01:50 PM | #6 | |
J. E. Reel Driveline 448 S. Reservoir Pomona, CA 91766 (909) 629-9002
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 07-29-2010 at 01:50 PM. |
07-29-2010, 02:02 PM | #7 |
Senior Car Nut
!!!, you do mean circumference, right?
1. you mean you swapped rear ends and now the driveshaft is too long? the only thing that would cause this(other than not locating it properly on the trailing arms) is if the new carrier is longer (what I mean is the pinion u-joint is further forward), if so measure the difference between the new and the old, that should be the distance that you need to shorten 2. I didn't think our trucks came with single piece shafts originally but maybe.
Larry Last edited by fleetsidelarry; 07-29-2010 at 03:05 PM. Reason: attempt to clarify |
07-29-2010, 02:21 PM | #8 | |
Do you think I should get a carrier bearing and carrier bearing bracket and find a 2-piece driveshaft for it? If I can get away with just cutting mine down and getting it rebalanced, or finding another one piece that will fit, i'd rather do that. alot easier and time effective, but if it is going to create problems such as vibration at higher speeds, i'd rather just go with a 2-piece. Thanks for the replies guys! |
07-29-2010, 02:59 PM | #9 |
Senior Car Nut
I'm still a little confused (not surprising at my age) is this the old driveshaft or the one out of the suburban?
Regardless, either solution is going to work. There's nothing wrong with either (actually 3 choices, as there is a heavy duty 2-piece shaft and carrier setup). If the previous owner torched the carrier bearing bracket out to make room for the 1-piece to move up and down (as was done on the donor truck I have) then it will be a lot more work to install the carrier bearing as this bracket is riveted to the crossmember. Lots of us out here running shortened driveshafts, good idea to get it done by a specialist but if you know your stuff go for it.
Larry Last edited by fleetsidelarry; 07-29-2010 at 03:10 PM. |
07-29-2010, 03:21 PM | #10 | |
07-29-2010, 11:43 PM | #11 |
60-66 Nut
If this was my truck, I would be going with the heavy duty 2 piece driveshaft. Probably still need to have the front shaft shortened, but a 2 piece is much better in a long wheelbase truck IMO.
Thread Tools | |
Display Modes | |
