Old 08-03-2010, 12:09 PM   #1
arm51
beer me
arm51's Avatar
bottom hose help
i got a different radiator, and the bottom hose is very tricky there is almost a 45 bend right in front the wheel well could i get a flex hose for it or would that be too much pressure
1969 c10 currently on hold because of a darn f**d
1986 f150
1986 silverado-my dads truck that i'm fixin up
ill keep my freedom my guns my money my religion and you can keep your CHANGE-hank williams jr
arm51 is offline   Reply With Quote
Old 08-03-2010, 01:03 PM   #2
michael bustamante
michael bustamante's Avatar
Re: bottom hose help
the bend is there I believe so the lower rad hose doesnt rub against the frame.
1967custom
michael bustamante is offline   Reply With Quote
Old 08-03-2010, 01:05 PM   #3
arm51
beer me
arm51's Avatar
could i use a flex hose, i have not been able to find a molded hose that will work but i've been told that a bend like that on a flex would be too much pressure on the neck
1986 f150
Old 08-03-2010, 01:18 PM   #4
michael bustamante
if the flex has the the internal spring I dont see why not. parts stor doesnt have a lower rad hose for a 72?
1967custom
Old 08-03-2010, 01:23 PM   #5
arm51
beer me
arm51's Avatar
no its a different rad that is about 1 1/2 inches longer than the original and i already had to drill new holes for the brackets, i don't believe that flex's have an internal spring
1986 f150
Old 08-03-2010, 02:32 PM   #6
vectorit
What?
vectorit's Avatar
You can get that molded hose from places like Napa AP, and probably every vendor has one to sell you. The flex hose would be a last resort IMO...
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-03-2010, 02:37 PM   #7
chisler
chisler's Avatar
Lower rad hose part# for the (oem style radiator) are for the.... GATES# 20694.... and if you want.... DAYCO #70664..... The GATES will have internal support spring the DAYCO will have no spring, either one will work with your truck as I have used both in my k10
chisler is offline   Reply With Quote
Old 08-03-2010, 02:46 PM   #8
arm51
beer me
arm51's Avatar
thanks everyone
1986 f150
Thread Tools
Display Modes
