Old 08-04-2010, 02:32 AM   #1
PugDad
PugDad's Avatar
Is a 1978 steering column the same as 1977?
Well, that's the question!
Anybody know for sure?
PugDad is offline   Reply With Quote
Old 08-04-2010, 02:47 AM   #2
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Re: Is a 1978 steering column the same as 1977?
Yup same thing assuming its from a truck.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 08-04-2010, 02:51 AM   #3
PugDad
PugDad's Avatar
Yep, from a truck...thanks 79gmc
Old 08-04-2010, 09:01 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
The column is the same. The connectors and pin out might not be. 77 was a transition year for our trucks. There are several things that started, several things that ended, and others that were one year only on the 77 model.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-04-2010, 12:39 PM   #5
OleBlue79
OleBlue79's Avatar
The end connectors are different but the shaft they connect to that goes to the steering box is the same. Swap the entire shaft assembly.
OleBlue79 is offline   Reply With Quote
Old 08-04-2010, 12:39 PM   #6
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
I agree that there were a few oddball items in 1977, but the tilt column I put in my '77 was from a newer truck (I don't remember exactly what year it was, but somewhere between a '78 and '80) and the only thing I found that was different was how the key cylinder was retained in the column. I had to pull the cylinder out of my old column since I didn't have a key for the new one, and it was a little bit of work to get it out. If I remember correctly, it was much easier to get the one out of the newer column, and the cylinder I was using slid right in.
And like OldBlue79 said, I swapped the entire assembly.
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 08-06-2010, 04:20 PM   #7
OleBlue79
OleBlue79's Avatar
I went home and checked my 77, 78 and 79. The connectors to the lower steering shaft are the same on the 77 and 78. It is a clamp that holds the two pieces together with a bolt through an ear on the clamp. In 79 it switched to a bolt that goes through the clamp and the center of the shaft. I hope this helps.
Old 08-06-2010, 04:42 PM   #8
WigglesTheHoly
IT Guy/ Father/ Chevy lover
WigglesTheHoly's Avatar
Unrelated but I swapped from a 76 to a 79 just two weeks ago and the only thing I had to change was the wiring. Must note too I was going from an auto to a stick.
78 Chevy (Pictures) SOLD
79 Chevy LWB (pasture)
83 Chevy LWB (crushed rusted beyond repair)
02 TrailBlazer SOLD
03 VW Passat wagonSOLD
95 extended cab silveradoSOLD (still in family)
05 Crew Cab Silverado 5.3 (The Turd)
WTB: 66 El camino
Technology Specialist aspiring to be a gear head.
WigglesTheHoly is offline   Reply With Quote
Old 08-07-2010, 12:57 PM   #9
vtwinsport
vtwinsport's Avatar
I swapped from a 76C10 to a 78 C10. Wiring harness pins holder was different, retainer clamp/ bolt was different, column to shaft was different, key cylinder is different and won't stay locked in column.
Get the whole assembly right down to the steering box.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Thread Tools
Display Modes
