Old 08-06-2010, 11:20 PM   #1
lts70
1970 Daily Driver
lts70's Avatar
Stainlees Steel Brake Flex Hoses Needed
Looking for the best deal on some good stainless steel brake flex lines. I have factory disc brakes and I am converting to rear disc brakes as well. I want to do all four corners in SS flex lines.
What are you guys using for rear line lengths. I am using the same calipers out back as the original fronts. Could I just use the same flex lines as one would run in the front?
Thanks guys
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 08-07-2010, 05:51 AM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: Stainlees Steel Brake Flex Hoses Needed
Here's the place that I used. I actually sent my rubber lines to them and asked them to duplicate my lines into Steel Braided Lines. Also, I was unsure of the fitting sizes so this way, there was no question. I think they were about $25 each if I remember right.
Here's the companies link: http://www.bonacoinc.com/
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 08-07-2010, 07:48 AM   #3
cdowns
cdowns's Avatar
speedway motors has stainless brake line kits for GM calipers
Old 08-08-2010, 01:52 PM   #4
colin_havens
colin_havens's Avatar
I used these guys for mine, but they were local when I lived in North MS. They are in Memphis TN. The old man that owns the business has been around drag racing forever, and really knows his stuff. They can get any length, and any fittings you need. However, if I remember correctly, they werent cheap. I bought 5 stainless lines (dont remember the lengths), fittings, and brackets, and it was around $200. But they look real nice.
http://www.godmanhiperformance.com/
colin_havens is offline   Reply With Quote
Thread Tools
Display Modes
