Old 08-07-2010, 09:00 AM   #1
Buick455
1 ton vs 3/4 and 1/2 ton cabs
Well I passed on the 1982 silverado cab as it had more rust than advertised. I was reading about 1 ton cabs and saw that the 1 ton cab was the same up to 1991. Is that the case and would a 1991 1 ton bolt on my 3/4 ton GMC 4x4 frame?
Buick455 is offline   Reply With Quote
Old 08-07-2010, 09:02 AM   #2
Buick455
Re: 1 ton vs 3/4 and 1/2 ton cabs
NOte: My GMC is a 1987.
Old 08-07-2010, 09:43 AM   #3
68 TT
Still plays with trucks
68 TT's Avatar
As long as it is a square body truck the cab will fit.
The only problem may be the transmission tunnel height if yours is the high hump and the donor has the low hump. You can make your tunnel fit the other cab if needed though.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-07-2010, 10:05 AM   #4
GM72K10
Next!
GM72K10's Avatar
the last year you will find a 1 ton square single body cab similar to yours is 89, and that would be on a 1 ton cab & chassis truck. After that (90-91) the only squares were crew cab 1 tons, K5 blazers and suburbans.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Thread Tools
Display Modes
