Old 08-07-2010, 07:57 PM   #1
coggonobrien
going to put a my 396 in my 69 k5, what do i need
k5 currently has a 350 and a th350. i know i need either to buy or make appropriate motor mounts. what else do i need to properly fit it to the transmission/frame. don't worry about the fuel other odds and ends. i'm just talking major components. bellhousings should be the same correct? also is can the smallblock fly wheel be reused?
Thanks,
David
coggonobrien is offline   Reply With Quote
Old 08-07-2010, 08:12 PM   #2
70BLAZERX2
Re: going to put a my 396 in my 69 k5, what do i need
as far as the motor mounts go..same thing,will bolt right up..as long as it is not a 454 (externallly balanced), small block large flywheel is the same thing.
I had a 454 in a 69 K/20 with mod only to firewall,by the passenger vavlecover..for clearance..
70BLAZERX2 is offline   Reply With Quote
Old 08-07-2010, 08:29 PM   #3
coggonobrien
great so i shouldn't have any alignment issues with small block motor mounts and the turbo350 in its stock location?
Old 08-07-2010, 08:32 PM   #4
68 TT
Still plays with trucks
68 TT's Avatar
Thanks,
David
I did the same swap to my 67 C10. Engine bolts in fine using the stock small block motor mounts. Bell housing and flexplate are the same between 350 & 396 so the trans will bolt right up.
I had to modify the front crossmember in front of the engine crossmember to clear my crank pulley.
You will have to check around for headers to fit a 4x4 with the big block. I don't know if the cheapo ones I got from Summit will work on a 4x4 or not. They fit fine on the C10 though. I had to trim a 1/4" off the extra wide 67 frame rail on the passenger side to make them fit but that was no big deal. You won't have to do that.
http://www.summitracing.com/parts/SUM-G9011/
You can always modify them to fit a 4x4 if you can't find some that will fit for the right price. I just did that with a set I had sitting around that I put onto my 78 K20. The passenger side collector flange needed relocated a few inches rearward and I had to pie cut all the tubes & shift the collector toward the engine a little to clear the leaf spring shackle. Took all of 20 minutes to do and a scrap piece of 3" tubing.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-07-2010, 08:35 PM   #5
68 TT
68 TT's Avatar
Didn't have to modify anything on the firewall for clearance.
Old 08-07-2010, 08:40 PM   #6
coggonobrien
great for headers i may just use the stock exhaust manifolds. the motor is out of a 69 caprice so hopefully i can feed pipe easily.............
Old 08-07-2010, 11:12 PM   #7
68K30
I bought a 1972 caprice to get the manifolds for my 68, used the manifolds on the truck as a 2wd and later as a 4wd, I did have to slightly trim the passenger side rail on the 4wd. The pipe fit was easy and the manifold part numbers were the same for the big cars and the 67 to 72 trucks.
Good luck
68K30 is offline   Reply With Quote
Old 08-07-2010, 11:26 PM   #8
coggonobrien
sweet, all the feedback i'm getting about how easy this is is really going to make me look like a bum if i don't get it done
Thread Tools
Display Modes
