Packrat
TH350 trans. changed fuild, filter, pan gasket. now shudders.
changed the trans filter and pan gasket. new fluid.
right after starting, it will shudder if I shift into D or R and move the truck slowly... if I let it warm up, it seems fine, thought it does seem to have harder transitions between gears. I checked the fluid, and it's not low. thoughts?
gone: --'07 Tahoe LTZ 4WD --'68 Firebird 400 Convertible gone: --'72 Chevy K20 |
Re: TH350 trans. changed fuild, filter, pan gasket. now shudders.
Did you check the fluid when it was hot? And do you have the correct dip stick?
Packrat
yes, checked when hot. it's the original dipstick.
mine did that when i first got it the kick down was loose and i rebuilt the carburetor. haven't had a problem since, except i have to stand on the manual brakes to keep it from taking off.
72 lwb farm truck 86k o.g. miles. 350/th350 89 toyota 3" drop 22r 4spd 2wd |
#5 | |
Packrat
hmmm. my kickdown cable isn't attached. it's been disconnected for as long as I've had the truck.... carb was rebuilt less than 1000 miles ago. vac lines look okay. has new brake booster and MC too...
Possible loose filter screws or missing or out of position filter gasket, I have overhauled several of these that customers diagnosed themselves and this was the problem.
Packrat
when I take my foot off the brake pedal, it's slow to "release"...
This might make me sound stupid, but did you check the level with the truck running?
Packrat
Yep. I'm gonna try and check all the vac lines again too. Just seems weird that my braking seems involved..
Between Trucks...
Put it into all the gears with the motor running. P R N D 2 1. Let it sit for a moment in each gear with your foot on the brake, then check the fluid level again.
Beat it to fit, Paint it to match... ![]() |
Thread Tools | |
Display Modes | |
