Old 08-17-2010, 10:42 AM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
Narrow Axle vs Stock
I have seen several threads recently asking about narrowing rear axles, or stock rear axles that are narrower than the original ones that came with our trucks. I plan on linking some of those threads here as well as compiling information from you guys. This will give us a reference thread for future use.
Are there any known good conversions that will fit under our trucks? Camaro, Impala, or ???
60-66
width-?
67-70
width-?
71-72
width-?
73-87
width-?
88-98
width-?
Narrower rearend- LINK
Chevy 10 Bolt Diff w/22x11 rears- LINK
anybody running 20x15 rear wheels..LINK
Cutting rear end- LINK
Pro stock wheels or not- LINK
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-17-2010, 12:05 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Narrow Axle
Ken,... just to clarify,... I assume your want drum to drum measurements?
(or wheel mounting point to wheel mounting point)
I use backing plate to backing plate, because it's easier to check with a vehicle setting on the ground with wheels on it. (maybe not as accurate)
Keith
Convert to disc brakes.
Old 08-17-2010, 03:06 PM   #3
Hart_Rod
Hart_Rod's Avatar
Re: Narrow Axle
In....
60-70 (early): 62"
70 (late)-72: 63.5"
http://quickperformance.com/Technica...us_measure.htm
http://www.carnut.com/specs/rear.html
http://www.chevytrucks.org/tech/rear_ends.htm
http://www.chuckschevytruckpages.com/models.html
http://www.layitlow.com/forums/lofiv...p?t509437.html
http://en.wikipedia.org/wiki/Chevrolet_C/K
Hart_Rod is offline   Reply With Quote
Old 08-17-2010, 06:46 PM   #4
SCOTI
SCOTI's Avatar
Re: Narrow Axle
Originally Posted by Hart_Rod View Post
In....
60-70 (early): 62"
70 (late)-72: 63.5"
The late 70 - 72 housing is the same width as a 73-87 housing.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-17-2010, 06:55 PM   #5
SCOTI
SCOTI's Avatar
Re: Narrow Axle
The 'backing plate to backing plate' method is more common. Unfortunately, it's also more confusing when being measured by different individuals.
Are they trying stretch the tape from side to side & including the mild bend in their dimension? One guy might while another doesn't. Or, are they measuring as far a possible in a straight line, making a reference 'tick' mark, & adding it all up?
What brakes does the possible swap candidate rear have? They make a difference when determining how much 'narrower' you need the overall length to be for exact placement of the wheel/tire combo within the body.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-19-2010, 10:30 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Narrow Axle
I never thought about that. I suppose the factory listed width would be a good starting point. I assume that would be wheel mounting point to wheel mounting point.
I have been trying to get caught up from my vacation and haven't been on much. I will try o spend time on this later this week.
Articles-
"Refining Sierra"
Old 08-19-2010, 11:47 AM   #7
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Narrow Axle
any chance you could add the lug measurements and quanity of lugs
I have been pondering this myself ??? I have a 70 which really throws me for a loop....I want the narrow one for obvious reasons...
Hottrucks is offline   Reply With Quote
Old 08-19-2010, 12:48 PM   #8
SCOTI
SCOTI's Avatar
Re: Narrow Axle
You can measure from the axle flange (adjacent to the backing plate) to the center-line of the truck arm u-bolt to figure out which one you have (wider or shorter version).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-19-2010, 05:29 PM   #9
Hottrucks
Hottrucks's Avatar
Re: Narrow Axle vs Stock
Do you happen to know what those #'s are???
I have 7 1/4 to the top of the U bolt hanger
and 58 1/2 flange to flange measurein over the cover
I think these are the #'s everyone is looking for???
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Thread Tools
Display Modes
