Old 08-18-2010, 07:34 PM   #1
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Spring removal
I've got a front crossmember sitting in the driveway that's due to be refurbished. I'd like to get the springs out before I start wailing on everything else.
If I remove the u-bolts on the LCA, will the control arms spread far enough to pull the spring out to the inside?
What's the free length of the spring?
TIA.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 08-18-2010, 08:41 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Spring removal
those springs are still under pressure, correct? in that case about the only safe way I could recommend would be to rent an inside spring compressor.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 08-18-2010, 09:43 PM   #3
hounddogs!
hounddogs!'s Avatar
Re: Spring removal
Yep. That much stored energy scares the bejeebers out of me. I was assuming I'd wind up getting a spring compressor, but was curious about first loosening the LCA.
DD '09 Pilot
Old 08-18-2010, 10:51 PM   #4
tcb-1
tcb-1's Avatar
Re: Spring removal
You can loosen it, but don't take it completely apart before compressing the spring. And just for saftey sake, tie a strap (or two) around the spring before you start. That way it won't jump out and bite ya!
Doug
Old 08-18-2010, 10:53 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Spring removal
You can also use that stored spring tension to help seperate your balljoints.
Keith
Convert to disc brakes.
Old 08-19-2010, 09:31 AM   #6
slapthefunkyfour
Super Newb
slapthefunkyfour's Avatar
Re: Spring removal
I've heard that the springs are under a LOT of tension, but the other day I removed mine to cut a coil, and all I did was remove the ubolts. I kept a jack under the control arm, and everything came off pretty easy. I didn't notice any scary tension.
If you have some scrap steel, a 1/2-13 tap, a few 1/2" nuts and a length of 1/2" threaded rod, you can build your own spring compressor in about 5 minutes.
Hmm, that gives me an idea. I'm gonna start a thread about how I built mine.
slapthefunkyfour is offline   Reply With Quote
Old 08-19-2010, 11:28 AM   #7
hounddogs!
hounddogs!'s Avatar
Re: Spring removal
There's no truck mounted to the x-member, so I can't do much with the floor jack
Think I will do the DIY compressor, though. Thanks for the push in that direction.
DD '09 Pilot
Old 08-19-2010, 06:51 PM   #8
raycow
Re: Spring removal
You don't need a truck. Run a length of chain under the floor jack and over the crossmember. Bolt the ends together and you are good to go.
Ray
raycow is offline   Reply With Quote
Old 08-20-2010, 12:57 PM   #9
hounddogs!
hounddogs!'s Avatar
Re: Spring removal
Got the pass side out last night without any drama. Strapped the bottom of the spring to the LCA and chained the floor jack up and over the stub of the frame. I then freed the LCA u-bolts and broke everything apart that way. Didn't need to use the spring compressor that I had rigged up.
Thanks, guys.
DD '09 Pilot
Thread Tools
Display Modes
