Old 08-24-2010, 09:34 AM   #1
BarnabyHooge
Pros/Cons to plug wires
I replaced my distributor recently which caused be to uproot all of my plug wires. Currently they hang in looms that come up off of the valve cover. I'd like to get new wires and I'm wondering if maybe I should reroute them under the headers (if posible). Are there any pros/cons to doing it tis way or is it just a style choice? Right now they seem to just be all over the place, which i can't imagine is very good, and it might be nice if they didn't block the valve cover.
Also, I've spent a bunch of time trying to find appropriate wires on 3 different sites and I'm having trouble pinpointing the ones that will fit. It's a '71 350 w/ Skip White HEI and long tube headers. Not sure what brand they are, but they are leaky and rusty! Any suggestions?
BarnabyHooge is offline   Reply With Quote
Old 08-24-2010, 10:44 AM   #2
Lee H
Lee H's Avatar
Re: Pros/Cons to plug wires
Route them anyway you want, no problem. I have mine routed down the back of the block, tucked close to the side of the block and up to the plugs with the two front wires between the block and motor mounts on both sides. Works well with headers (and stock manifolds) and out of sight for the most part. I use mid 70s corvette part number for the wires. These have HEI ends for the cap and 90 degree boots for the plugs, and most important, they are long enough.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-24-2010, 12:47 PM   #3
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
cons:
diesels are so cool!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 08-24-2010, 01:48 PM   #4
QKENUF4U
QKENUF4U's Avatar
heres what i did with my bb wires... nice and clean...got the holders etc. from CHECKERS.
QKENUF4U is offline   Reply With Quote
Old 08-24-2010, 02:23 PM   #5
cdowns
cdowns's Avatar
i've always liked the up top ones so i can see the condition of the wires easily and the slightly shorter plug wires required to run them that way
Old 08-24-2010, 06:14 PM   #6
raycow
Factory installations on engines with rams horns had the wires routed behind the heads and then up to the plugs from below. This arrangement protected the wires very well against burning.
Ray
raycow is offline   Reply With Quote
Old 08-24-2010, 08:33 PM   #7
Mike C
Mike C's Avatar
Yup. If you are going to run headers and a small block, I would run them underneath. Get a set of factory fit wires if you have points type cap and get a '75 Corvette HEI set if you have converted to the HEI style cap/distributor.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-24-2010, 11:00 PM   #8
BarnabyHooge
Thanks everyone
Old 08-25-2010, 03:22 AM   #9
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
[QUOTE=QKENUF4U;4155134]heres what i did with my bb wires... nice and clean...got the holders etc. from CHECKERS.
Is Checkers a parts chain store?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-25-2010, 06:30 AM   #10
brans72
Good post anymore pics?
brans72 is offline   Reply With Quote
Thread Tools
Display Modes
