08-25-2010, 11:55 AM | #1 |
Sterring Wheel removal
How are you guys getting your wheels off the sterring columns? I have a puller I used to remove 69 camaro wheels but it doesn't seem to fit the truck sterring wheels.
08-25-2010, 12:04 PM | #2 |
72 GMC
Re: Sterring Wheel removal
use a puller and keep your teeth
08-25-2010, 12:12 PM | #3 |
Between Trucks...
I use one of those generic universal pullers that you use for harmonic balancers and things like steering wheels.
Beat it to fit, Paint it to match... |
08-25-2010, 12:57 PM | #4 |
i loosen the nut ,put pressure on the back of the steering wheel with my knees and wack the shaft and nut with hammer handle to loosen it up.
08-25-2010, 07:08 PM | #5 |
trying the wack trick first then I will pull out my NB puller. Thanks guys
08-25-2010, 09:10 PM | #6 |
08-25-2010, 09:17 PM | #7 |
Grandpa in the rustmobile...
lol pull at her ya sissy!! lol My scrawny butt can do it! 140lbs lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-25-2010, 09:37 PM | #8 |
Darn, at 200 lbs and a frameing hammer I still can't get the SOB off. At this point the socket can bearly get back on the nut. I am going at it one more time its either coming off or the column will not be usalble!
08-25-2010, 09:54 PM | #9 |
OK. its off. I used a larger socket with a nut in it and placed it over the threaded nut on the column and gave it a full swing with the hammer. Thanks for the help guys!!!
08-25-2010, 10:54 PM | #10 |
20' Daredevil (Ret)
For next time.... these are cheap, and they work:
Thread Tools | |
Display Modes | |
