Old 08-31-2010, 09:41 PM   #1
82gmc_sb
82gmc_sb's Avatar
Lowering Problems - Need advice
I just installed 3" drop lowering springs (SUM-G726 ) and djm's 3" drop spindles on my 1982 gmc 1/2 ton shortbed. The problem is, I didn't know it was gonna be sitting on the bump stops and the tire touches the top of the wheel well. Also the tire rubs on the fender. It has 235/75r15's right now. What can I do to actually drive it???
82gmc_sb is offline   Reply With Quote
Old 08-31-2010, 09:49 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: Lowering Problems - Need advice
cut off the bump stops, remove the inners, and you might need a shorter tire
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-31-2010, 09:57 PM   #3
SBTork
Garage wrench
SBTork's Avatar
yes, yes and yes. It's all worth it to look cool too
Something I did, you may or may not want to consider it. I switched to a 225/70R15 front tire to help my clearance issues and it's helped a lot on my suburban. It's lowered about 5", 5.5". I cut my bump stops off and have yet to remove the inner fenders but probably will in the spring when I bag it.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 08-31-2010, 10:04 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
If it were me, I would go with a lower profile tire and get rid of the 3" spring. I would cut one coil off of the stock spring and go from there.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-31-2010, 10:14 PM   #5
bigwheel15
bigwheel15's Avatar
When you said your tires rub on the fender, are you talking about the lip on the fender?
bigwheel15 is offline   Reply With Quote
Old 08-31-2010, 11:00 PM   #6
mrnize
mrnize's Avatar
Ok I just got done lowering my truck, same situation... SO I boughts some used tires stock(craigslist) , with stock or thin tall tires. Thin, gives it the "tucking" and taller, actually gets it off the ground!!
As the bump stops, I took a file, basically turning it into a hot knife and trimmed my bump stops about a half inch... Wether or not its enough, who knows it rides fine to me.. Good luck..
Get that thing to a tire and wheel shop, pick out some rims and tires then throw them in the bed and make an appointment for an alignment ASAP
mrnize is offline   Reply With Quote
Old 08-31-2010, 11:01 PM   #7
SCOTI
SCOTI's Avatar
You can remove the bumpstop but it's just going to be limited by the next obstacle. You can remove the bumpstop & get a shorter tire (yours are 28.75" tall now; 225-70's would be 27.4" tall). You can do the bumpstop, tire swap, & remove the inner fenders & all those will introduce you to the next obstacle.... those a-arm bushings will find the road surface quickly. The more travel you have w/o being limited somehow, the worse the problem of the a-arms hitting the road surface will be.
I actually use a combination of the above to keep mine from hitting the road. The bumpstops keep the tires from constantly buzzing the top of the inner fender wells. If the stops compress enough, the tire contacts the inner well which keeps the a-arms from hitting the road. Even w/these limitations, my lower a-arms are beat to crap from the lovely roads in my area because I drive mine daily.
For the record, my combo is a 74swb, 3" BTech spindle, 1-coil removed from the factory coils, relocated upper shock mounts, & ~27" tall front tires.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-31-2010, 11:13 PM   #8
82gmc_sb
82gmc_sb's Avatar
Thanks alot for the help. I'll get to it
Old 09-01-2010, 01:19 AM   #9
flamingbig10
6.0 powered square
flamingbig10's Avatar
mines a daily also, I have 3" coils and spindles on mine with a 215/70 and before I added some stubbie bumps stops the top of tires would hit the inner fenders on every little bump, and also every time I jack up the front end the coils are loose in the control arms
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-01-2010, 09:08 AM   #10
mrnize
mrnize's Avatar
Do you have header collectors that hit the ground lol?
I have about 3 inch's of header collector clearance otherwise with a 5 inch drop in front and 20's its good to cruise.
Old 09-01-2010, 03:43 PM   #11
Matt Man
Matt Man's Avatar
x2
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 09-01-2010, 05:20 PM   #12
Can't kech me
Can't kech me's Avatar
my dads '98 did the same thing and i'm expecting it when i lower my '82
"As I walk through the valley of rice i fear no honda, for i have torque!"
Can't kech me is offline   Reply With Quote
Old 09-01-2010, 07:08 PM   #13
flamingbig10
6.0 powered square
I have plenty of clearance
Aaron
Old 09-01-2010, 11:03 PM   #14
Yupiamlo
Yupiamlo's Avatar
I have an 85 with DJM 3" Coils and 2" spindles and a flip kit, with removed bump stops, Im running 215/70/15 up front and 225/70/15 out back and I don't have any problems.
As for putting your stock springs back in and cutting them that sounds dumb to me. You just paid for springs and their designed to be lower, your stock ones aren't cool looking, beat, and aren't meant to be cut. Just an IMO though, I just wouldnt wanna waste the money.
-Adam
Yupiamlo is offline   Reply With Quote
Old 09-01-2010, 11:26 PM   #15
West Texas Z
El Mero Mero Frijolero!!
West Texas Z's Avatar
-Adam
West Texas Z is offline   Reply With Quote
Old 09-02-2010, 12:50 AM   #16
SCOTI
SCOTI's Avatar
-Adam
Cutting stock springs is free. If it doesn't work for him, he can always put those 'designer' springs back in..... all the cool guys are doing it .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-02-2010, 11:45 AM   #17
82gmc_sb
82gmc_sb's Avatar
I removed the inner fenders and the bump stops, but I still need smaller tires. So I go to pull it out and its grinding metal on metal. The spindles are rubbing on the inside of the 15" wheel. Anybody else run into this problem?? I plan on gettin bigger wheels in the future, but for now Im thinkin of grinding down the spindle so the wheel will spin.
Old 09-02-2010, 11:55 AM   #18
SBTork
Garage wrench
SBTork's Avatar
It's almost a common problem with the 3" spindles, grind away, you should be fine.
-Adam
Old 09-02-2010, 12:09 PM   #19
JHT67
JHT67's Avatar
Man that stinks. Always something though, isn't it? I can't seem to get ahead on my truck, and I haven't tried to customize anything yet, so I see what I've got to look forward to. Hope you get it the way you want it soon.
JHT67 is offline   Reply With Quote
Old 09-02-2010, 12:34 PM   #20
82gmc_sb
82gmc_sb's Avatar
All I planned on doin was the springs and spindles. Next thing I know Im doin brakes, rotors, brake hoses, tie rods..... It never ends
Old 09-02-2010, 01:20 PM   #21
SCOTI
SCOTI's Avatar
Were they worn? If so, you would have needed to do it anyway as leaving it could of created more issues. It's easy to forget that all vehicles (including paid for old ones) require maintenance investments from time to time.
As was stated, it's not uncommon to need to smooth the edges a little bit on the spindle when using 15's. You might also need to trim the lower a-arm lip slightly depending on the wheels width & back-spacing.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-02-2010, 08:55 PM   #22
82gmc_sb
82gmc_sb's Avatar
Ok, I smoothed down the spindle and the wheel spins. So I took it for a drive and as I figured it hits the inside of the fender. So im ready to start choppin but I thought I would would brainstorm it first. Heres a pic to show you what Im talkin about.
Old 09-02-2010, 09:02 PM   #23
bigwheel15
bigwheel15's Avatar
Roll the fender lip instead of cutting.
Old 09-02-2010, 09:08 PM   #24
mooseknuckles
mooseknuckles's Avatar
mine did that too so I cut an "arch" in the fender for clearance
mooseknuckles is offline   Reply With Quote
Old 09-02-2010, 09:19 PM   #25
82gmc_sb
82gmc_sb's Avatar
Got any pics? Did it affect the stability of the fender at all? The reason I ask it because the hood hinge is attached right there.
Thread Tools
Display Modes
