Old 02-24-2003, 12:04 PM   #1
krazy_texan
krazy_texan's Avatar
transmission problems (i think)
ok my problem is getting worse i will be driving around town and when i come to a stop, when i get ready to leave the stop i will apply the gas and the truck will rev for a little bit and then it will catch and start going with a haevy jolt is this my transmission screwing up, any and all help is appreciated as this is my dailey driver and my burb is no where near street ready
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 02-24-2003, 12:10 PM   #2
mtdave2
newly minted old timer
mtdave2's Avatar
are you low on trany fluid??
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 02-24-2003, 12:13 PM   #3
krazy_texan
it has plenty of fluid i checked it last night
Krazy Texan
1990 v1500 suburban
Old 02-24-2003, 12:48 PM   #4
kxmotox247
kxmotox247's Avatar
That's the first thing I would check. Make sure your vacumm line is hooked up with no air leaks also.
Other than those two pointers...I don't know.
kxmotox247 is offline   Reply With Quote
Old 02-24-2003, 12:56 PM   #5
72CustomCamper
Sounds like one or more of the friction plates is burned up. First chance you get, pull the pan and filter and look for little pieces of what looks like burnt paper.
Another check: smell the fluid on the dipstick. If it smells like paint thinner, the fluid is shot.
If there is none of that then maybe the torque converter is somehow not getting enough fluid...
The 4L80E in my '93 started doing that...$2600 later, it is better than new with custom fluid ports for cooling and a solid shift-kit.
Your tranny shouldn't cost half of that for a complete rebuild.
'72 GMC C20, "2500 Super Custom", Custom Camper, New 454
'93 K2500 Suburban, Old 454 (157K)
72CustomCamper is offline   Reply With Quote
Old 02-24-2003, 03:11 PM   #6
Jason71k10
ready for reassembly
Jason71k10's Avatar
that kinda sounds like what mine is doing, but mine actually goes in to nuetral when i'm at a stop light. The shifter(on the column) doesn't actually move, but if i wiggle it just a bit, it goes back into drive?? It seems to do it only before the engine is nice and warm
anyone have any ideas on that one?? it's a th350 and was rebuilt about 8k miles ago(about a yr and an half)
Jason71k10 is offline   Reply With Quote
Old 02-24-2003, 04:24 PM   #7
COBALT
COBALT's Avatar
Make sure you have a bottle of ATF around. Dip your finger in it and check it against the dip stick reading. If the fluid on the dip stick is darker than what's in the bottle then your clutch packs are buring up. If your fluid is even got a brown-ish color then it's time to rebuild the transmission.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Thread Tools
Display Modes
