72 truck with 71 doors panel question
Previous owner of my truck had put a piece of plywood wrapped in carpet on as a door panel. I bought new door panels expecting to put them off when we paint. Yesterday I went and checked the body shop and found out the doors are actually from a 71 it looks like. When we moved the carpet there was no holes for the door clips. Just 4 or 6 screw holes on the corners for a panel. I am guessing that is for the metal 71 panels? I would like to make it look like a 72 inside. Is there a way to make this happen? If I drill holes for the clips on the 72 panel maybe? The door handle and mirror matched holes, but I know one sets in deeper than other. Thanks for any input.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
Old Skool Club
![]() Join Date: Jun 2001
Re: 72 truck with 71 doors panel question
I know the door panels for '72 are different, and that means that the window regulators and door relays have longer shafts for the handles to clear the panel. I am unaware that the door is different, just because the panel is different.
What tells you that the door is one year or the other?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
The door on the 72 has holes for the clips on the back of the door panel to slide into. This door has factory made screw holes for a screw to go in on all 4 corners. I know the regulators stick out farther on the 72. I am curious if I could modify my panel a little to make the handles slide on.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project Last edited by srea76; 09-02-2010 at 12:12 AM. |
The previous owner of my truck did it to mine.... He just drilled holes in the door for the clips.... I didnt even think about the shaft length.....if thats true then that explains why mine are a little tight
Anyone have pictures of the 72 door panels on older doors? Do that work ok?
![]() Join Date: Oct 2008
You might find it a benefit to check out my build thread (post #378) http://67-72chevytrucks.com/vboard/s...318544&page=16 that I just posted, that deals with some of the differences between doors and inside panels.
I’m converting my 72 door shells to a 68-71 inside flat door panel
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544 |
Thread Tools | |
Display Modes | |
