02-24-2003, 05:25 PM | #1 |
Can Someone Check a Part Number for me?
The part number is 7815989. Thanks
02-24-2003, 09:44 PM | #2 |
What are you wanting to know? Availability, cross reference, application? What is it.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
02-24-2003, 10:50 PM | #3 |
Here's what I have:
7815989 - CE, CM, CS - Type 525-A - not used w/ power steering - 1967, 8, 9 -- repl 5697954, 7802646, 7812905. Second line says: 7815989 - CE, CS - Bolt 7/16 -14 X1-1 1/4 He Hd, 300M Steel -- Not used w/Power strg - 1970, 1, 2 -- Repl 7808710, 7812905 Whatever that means. It is under the heading 16.0010 GEAR - STEERING in the GMC Master Parts Book. The first line (for 67-69) has notes that it is for 1/2, 3/4 and 1-ton, the second line (for 70-72) says it's for 1/2 and 3/4 ton.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
02-24-2003, 10:59 PM | #4 |
Here is a site that works for part numbers sometimes
http://www.gmpartsdirect.com/multiSearch.cfm GM PART # 7815989 CATEGORY: Steering Gear PACK QTY: 1 CORE CHARGE: $0.00 GM LIST: $397.71 OUR PRICE: $226.69 DESCRIPTION: GEAR ASM |
02-24-2003, 11:01 PM | #5 |
It is a NOS steering gear box I have. I want to make sure what it is before I list it on Ebay. Thanks
02-25-2003, 04:36 AM | #6 |
Could someone check this part number too: 5698180
It is another gearbox. I would like to find what it was used for. Thanks |
02-25-2003, 04:47 PM | #7 |
ckhd, sounds like a good book to have. Are they still available?
02-25-2003, 08:18 PM | #8 |
I have a copy of the GM parts manual, I assume thats also what he is using. If you are in the good with your local GM dealer and have a photocopier and alot of time and paper you too could have a copy. Or they might have them on ebay or something, the set I have takes up 2 4" binders!
Thread Tools | |
Display Modes | |
