Never Ending Projects
Need a front suspension measurement please
Hi guys,
The PO had put Ground Force 3" dropped spring (or so he says) and I only have about 1" between the A-arm metal stop (missing the rubber) and the crossmember stop. Needless to say, it bottoms out all the time. I picked up some 2.5" dropped spindles and want to verify what spring height I need to keep it at the current height. I like how it sits but want more travel. Can someone with with a known amount of drop (i.e. spindles and aftermarket springs, not sagging 45+ year old stock springs) please measure from the center of the spindle to the lower edge of the fender? This will take out any differences in tire height. This will help me figure out where I am at and how to get there. Please, no ground to the fender lip measurements UNLESS you are running 235/70-15" tires on 15x7" wheels. This would match mine and would then be relevant to me. Thanks a bunch!!!
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Re: Need a front suspension measurement please
Anyone???
Just need someone with a known drop and a tape measure. ![]()
Thread Tools | |
Display Modes | |
