Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 02-26-2003, 08:58 PM   #1
PHOENIX
LOW84 (Fan Shroud Pictures)
There is a total of 5 pictures.
If you need anymore or measurements just let me know.
Like I said it will fit a 4-row modine "MO730" without a problem.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 02-26-2003, 09:00 PM   #2
PHOENIX
The above picture is the outside (closest to engine)
This picture is the inside (closest to radiator)
Old 02-26-2003, 09:02 PM   #3
PHOENIX
Corner Shot #1
Old 02-26-2003, 09:03 PM   #4
PHOENIX
Corner Shot #2
Old 02-26-2003, 09:04 PM   #5
PHOENIX
Here is a picture of my quality control agent approving this product
Old 02-26-2003, 10:21 PM   #6
low 84
low 84's Avatar
lmao, thats great man does the quality inspector come with it?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-27-2003, 12:28 PM   #7
PHOENIX
Notice how it doesnt come off the radiator as far as a 3-row shroud does. That makes a big difference on the fan you use. Like I said before I had a flex fan on there with a 5"-6" extension and the fan wouldnt go into the shroud at all. The blades were about 1" away, which didnt create enough pull to work well. With a stock fan clutch system you shouldnt have any problem.
Old 02-27-2003, 03:44 PM   #8
low 84
low 84's Avatar
i'm not using a clutch fan. can i not get an extension long enough for a flex fan to reach?
'05 1500 Crew Cab
RIP
Old 02-27-2003, 04:14 PM   #9
PHOENIX
Im sure you probly could, but I havent seen them. Never really looked either.
Thread Tools
Display Modes
