Old 10-04-2010, 09:06 PM   #1
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
ignition and key tumbler assembley
so... my truck has been starting funky latley, i would put my key and turn it but nothing would happen. all the accessories would come on, but to turning over or ignition. but after 2-3 tries it would start. about an hour ago i went to turn my truck on and the same thing happened again. i turned the key a bit and the whole tumbler flew out! haha... i was just wondering if this is a pretty easy fix? i work tomorrow but i can be a little late to fix this, is this something that is time consuming?
"san diego chargers #1"
joe1982 is offline   Reply With Quote
Old 10-04-2010, 09:20 PM   #2
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
Re: ignition and key tumbler assembley
here are some pics
Old 10-04-2010, 09:27 PM   #3
texasfunk
texasfunk's Avatar
not too time consuming, but can bea pain in the a** if you dont know what your takingoff, pull the steering wheel off, then use a steering whel tool to compress the plate and spring that lock the wheel and remove the clip(snap ring) that holds them down, after that remove the signal lever, and the signal cam, use a pair of needle nose to remove a piece of plastic that covers a torx right under the ignition lock cylinder, once that screw is off, should pull right out, then reverse the process....hope it wasnt too confusing...
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
Thread Tools
Display Modes
