Old 10-07-2010, 10:05 PM   #1
Patriot
Question Can the 203 be adjusted in the Blazer??
My 77 Blazer won't go forward unless I lock it in High Lock. I need to adjust the linkage for the 203 and was wondering if anyone has done it in the truck?? It doesn't seem to have enough room under there. Any help would be GREAT fellas.
Thanks in advance.
Patriot
Patriot is offline   Reply With Quote
Old 10-08-2010, 06:13 AM   #2
LONGHAIR
Re: Can the 203 be adjusted in the Blazer??
Although these shifters do have their "issues" and a good cleaning/adjusting is definately a good thing.....If it won't move with-out being locked, you probably have a bigger porblem.
Has this transfer case been converted to "part-time" 4 wheel drive?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-08-2010, 03:42 PM   #3
Patriot
Question Re: Can the 203 be adjusted in the Blazer??
I don't know for sure. I replace the tranny and transfer case form a Suburban the same year. The original tranny only worked in reverse and the fluid smeeled burnt. That is the way I bought it, so I replaced both tranny and t-case. It does have lock-outs on the Dana 44 front but I am not sure if the original t-case has the part-time conversion. Is there a way to know for sure just buy looking at it??
Thanks for your reply.
Old 10-08-2010, 03:48 PM   #4
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
lock in the hubs and see if she will move forward then. With the hubs unlocked a stock 203 in either high or low (non lock) wont move anywhere.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 10-08-2010, 04:59 PM   #5
willett
Another Day, Another Dollar
willett's Avatar
sounds like you need a mile maker kit to disable the dif inside of your 203
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Thread Tools
Display Modes
