Old 10-08-2010, 05:19 PM   #1
blackbeaSSt
uh oh. truck started getting the chugs and shakes after i turn it off
i've always seen peoples older cars/trucks do that. i don't wanna turn into "that guy" that people stare at all the time! could my ghetto carb setup be causing it?
blackbeaSSt is offline   Reply With Quote
Old 10-08-2010, 05:49 PM   #2
baclay9
Re: uh oh. truck started getting the chugs and shakes after i turn it off
My Dad's engine did that. I think it was because his timeing was advanced too much or something.
baclay9 is offline   Reply With Quote
Old 10-08-2010, 05:55 PM   #3
Sooner84
Sooner84's Avatar
My truck does this when its hot outside and its been running a while.
1984 chevy swb(1st truck, sold..)
2001 RCSB silverado, 5.3 with a little extra
2004 ECSB Silverado LT, 5.3 cam & bolt ons, 4l60e shift kit/stall, g80 & 3.73s
My first (1984 c10) Build
Sooner84 is offline   Reply With Quote
Old 10-08-2010, 06:19 PM   #4
irishman999
irishman999's Avatar
Your truck is dieseling, I saw your zip tie rigged carb and would probably start with your carb. Im not the brightest flash light but managed to rebuild my quadrajet and it only cost 25 bucks for the gasket kit. If you decide to rebuild it yourself do plenty of research online, I saw alot of how to video's on youtube.
irishman999 is offline   Reply With Quote
Old 10-08-2010, 06:21 PM   #5
C low
C low's Avatar
its prob timing if it runs good just shut it of in drive that will kill the engine right away
C low is offline   Reply With Quote
Old 10-08-2010, 06:51 PM   #6
blazer2007
I know my dist. was walking abit over time and I just reset the timing
blazer2007 is offline   Reply With Quote
Old 10-09-2010, 10:33 AM   #7
76/85 Truck
76/85 Truck's Avatar
My truck does the same thing. When fuel enters the cylinder, it becomes a vapor, and when your engine heats up (mine runs about 205-210 degrees) I think the hot cylinder walls ignite the fuel vapor, simply because vapor ignites better and quicker than liquid gasoline. And so when you shut the truck off, the pistons come to a stop and allows the fuel vapor that just got squirted in to sit for a split second, and it fires and drives the piston down. Anyone else think so? Just my .02
Rich
My first truck!! 1976 Chevy 3/4 ton Camper Special and a 1985 GMC body. Has a 350, 4 BBL Edelbrock, with a Turbo 350, and NP205 T-case.
76/85 Truck is offline   Reply With Quote
Old 10-09-2010, 10:38 AM   #8
nbpro
x2^^
nbpro is offline   Reply With Quote
Old 10-09-2010, 10:50 AM   #9
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Timing , sometimes idle speed too high. Vacuum advance not plumbed to a ported vac source............
powerdriver 1958 is offline   Reply With Quote
Thread Tools
Display Modes
