Old 10-09-2010, 04:02 PM   #1
miller6t9
miller6t9's Avatar
rear end, SPID, gear ratio question
ok...the SPID shows that my truck came with a G80 Posi-traction rear end (no other rear end options listed), the M49 turbo hydra-matic and the LS9 350 engine. Am I correct to assume the rear end ratio was a 3:73?
miller6t9 is offline   Reply With Quote
Old 10-09-2010, 05:19 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: rear end, SPID, gear ratio question
nope, the 3.07 gearset was standard with the 350/automatic
Old 10-09-2010, 05:27 PM   #3
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Never assume anything, you should know better!
Longhorn is right, unless they got changed somewhere along the line
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 10-10-2010, 11:16 PM   #4
aintmisbehavinn
If mine is a 307, why does it tach 2200 at 53mph? 350 automatic OEM
aintmisbehavinn is offline   Reply With Quote
Old 10-11-2010, 12:09 AM   #5
Longhorn Man
i think a 307 was the exception to the rule, i think it may have gotten a 3.73.
However, 'taching out' (to me) indicates redline... 5500 or so RPM... ?
you may have a problem there.
Old 10-11-2010, 01:12 AM   #6
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Best thing to do is pull the rear diff cover off to see what you really have. If you haven't ever changed the fluid it is a great time to do so. It is real easy to tell what you got once you are in there. you just wipe off the edge of the ring gear that faces to the rear of the truck and look for some #'s. If it is a 3.73 for example it will say "11-41", this indicates the ring has 41 teeth and the pinion has 11 teeth. Then you just divide the big # by the little #, so it would be 41/11=3.72727... so 3.73. It really doesn't take long to do, I checked 3 rears in the junk yard the other day and it only took 30 minutes (I didn't have to put them back together though ). Good luck!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 10-11-2010, 08:30 AM   #7
miller6t9
miller6t9's Avatar
I was looking at the specification list on the '72 brochure (http://www.lov2xlr8.no/brochures/che...v/bilder/9.jpg) and best I could tell the 3:73 was the standard gear and the 3:07 was optional.
Old 10-11-2010, 01:33 PM   #8
OhOneWS6
OhOneWS6's Avatar
There is something strange about that literature. Those are not the GM names for those colors.
OhOneWS6 is offline   Reply With Quote
Old 10-11-2010, 01:40 PM   #9
cdowns
cdowns's Avatar
if in doubt do your rear a favor and drain the 40yearold sludge out of it clean and fill with new. in the process you can take any guesswork out of the equation and ID your gears and carrier
Old 10-11-2010, 05:15 PM   #10
Longhorn Man
in a base model truck, that is true.
Once you get an optional engine, or tranny, or both, it may include a gearset in the rear as standard with that combination.
Old 10-11-2010, 05:30 PM   #11
68C10HotRod
68C10HotRod's Avatar
Here's a copy of some 71 data that might shed some light.
Of course, I've already found a number of times the "parts" don't always match the SPID. As others have said, checking is always the sure way of knowing.
Bryan
'52 Bel Air 2dr HT - in pieces
'68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed
Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin
"And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery)
68C10HotRod is offline   Reply With Quote
Old 10-11-2010, 07:53 PM   #12
aintmisbehavinn
It must be a 3.73 as the original owner quoted, it's not listed anywhere in the codes on the glove box door. I did change the fluid, I'll know for sure when it goes in for a limited slip diff.
Thread Tools
Display Modes
