Old 10-10-2010, 10:35 PM   #1
cstm68
cstm68's Avatar
compressor help (air ride)
hey guys quick question about compressor relays. im running 2 viair 444 compressors and a relay for each. on the 12v power wire from the battery to the relays i installed a 30 fuse, i keep blowing the fuse though if the compressors run for a while.
my question is, with the 2 relays (one for each compressor) do i really need to run a fuse between them and the batt. or if i do should i nuse a bigger fuse like a 50 maxi fuse?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 10-11-2010, 01:51 AM   #2
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: compressor help (air ride)
I just googled it and the max amp draw for each compressor is 38 amps, so it sounds like you need a bigger fuse. You should definitely have a fuse near the batt. because if the wire ever gets rubbed and grounded it will start a fire real quick. I had an amplifier in an 84 tempo and it got shorted out one day when I was leaving for lunch at highschool, the excessive current draw caught my alternator on fire and I was out there trying to blow it out, luckily someone had an extinguisher and they put it out for me before there was too much damage. The moral is if I would have had a fuse it would have never happened. Also as a side note what gauge wire are you running from the battery to the relays? I would run a minimum of #8 or maybe even #6 because 80 amps is a pretty big draw. Too small a wire will cause voltage drop to the compressors which will cause alot of heat, this will significantly shorten their lives.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 10-11-2010, 05:05 AM   #3
boostin20
boostin20's Avatar
On the last build I did, I used 8ga wire and an 80-amp maxi fuse (distribution block type) at the battery and ran 10ga wiring to the relays. I wouldn't do any smaller than that for any of my builds.
boostin20 is offline   Reply With Quote
Thread Tools
Display Modes
