Old 10-12-2010, 01:29 AM   #1
sixshooter798
Desert Rat
sixshooter798's Avatar
Gotta smog soon... any suggestions?
The time has come again for me to smog my 77 C10. She has a stock 350/350 with all of the smog junk still attached. I recently installed an Edelbrock 1400 carb because the Quadrajet kept causing it to fail. Does anyone have any advice on how to help the old girl pass smog a little easier?
sixshooter798 is offline   Reply With Quote
Old 10-12-2010, 02:18 AM   #2
Number21
Number21's Avatar
Re: Gotta smog soon... any suggestions?
Pour some 99% rubbing alcohol or "Heet" gas dryer (same thing) into your tank with as little gas as you can get away with. It may run like crap but it will burn cleaner. Otherwise make sure it's good and hot before testing.
Number21 is offline   Reply With Quote
Old 10-12-2010, 03:13 AM   #3
Michael Hill
Or you can put some denautered alcohol in your tank with a little gas and it will pass with flying colors. Just make sure that after you pass the smog you go and fill up the tank to dillute the alcohol that is left in your tank.
Michael Hill is offline   Reply With Quote
Old 10-12-2010, 06:48 AM   #4
GMC Guy
GMC Guy's Avatar
Seafoam the **** out of it
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 10-12-2010, 07:08 AM   #5
xrcr
I used to put in some methanol,lean it out and run the crap out of it right before it was sniffed in my 76. Then I said screw it and got historic tags
xrcr is offline   Reply With Quote
Old 10-12-2010, 08:13 AM   #6
68 TT
Still plays with trucks
68 TT's Avatar
Set the idle mixture screws for maximum vacuum.
Set the base idle to as high as they will allow in the test. Here it is 1100 rpm. Check with your testing station to see what they will allow.
As stated earlier, make sure it is good and warmed up.
Make sure you do not have any exhaust leaks. They really throw off the test.
People have told me in the past to run it a quart low on oil when you take it in for testing but I have never done it. Supposedly it creates less windage tossing oil onto the cylinder wall so less oil burning.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 10-12-2010, 05:46 PM   #7
83burban
Change the oil, run seafoam through it, and pour alcohol into the gas tank. I always run this crap out of it right before I take it in, so that the cat is good and hot if equipped.
83burban is offline   Reply With Quote
Old 10-12-2010, 08:13 PM   #8
Oilbrnr
Oilbrnr's Avatar
Go to church the Sunday prior to the test.
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 10-12-2010, 08:57 PM   #9
sixshooter798
Desert Rat
lol
Old 10-12-2010, 08:59 PM   #10
sixshooter798
Desert Rat
how much of this stuff should I buy?
Old 10-12-2010, 09:07 PM   #11
sixshooter798
Desert Rat
So.... is that as far clockwise as possible or vice-versa?
Old 10-13-2010, 02:38 PM   #12
Malo83
Cruzzzn' Vet
Malo83's Avatar
My routine for my 83 is a good tune up, plugs,cap and rotor new air filter and spray out PCV valve with carb cleaner and spray down carb and down the throats while in a high RPM. fresh oil and filter, add a bottle of Guaranteed to Pass additive to the tank and run the sheeet out of her down the highway to get her nice and hot and straight to the smog station
she hasn't failed yet
* make sure your timing is right on.
Malo83 is offline   Reply With Quote
Old 10-13-2010, 02:48 PM   #13
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Sorry little oftopic
what happens if you truck/car dosent pass smog? do you get a second change?
when the trucks that user krazyray parts out with the CA DMV fees? why dose these fees come?
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 10-13-2010, 02:49 PM   #14
MTCK
MTCK's Avatar
Max vacuum is the highest vacuum you see on a vacuum gauge while adjusting the idle mixture screws. 15 bucks at your parts warehouse for a vacuum gauge. Also do the timing, as mentioned.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 10-13-2010, 04:21 PM   #15
sandnuriz
sandnuriz's Avatar
1. You have a your smog crap on it?
2. Your new Edelbrock carb have smog tag on it and paper work?
3. Have you failed the test already?
4. Find a good smog shop and bs with them it helps!
Smog is a joke here in Cali. trust me
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project)
It's your ride build it the way you want !!!!!!!!!!
sandnuriz is offline   Reply With Quote
Thread Tools
Display Modes
