Old 10-21-2010, 03:52 PM   #1
Jay146992
Jay146992's Avatar
Help me identify my front end
This is the front end in my 79 k10. I was told it had been replaced but I don't know. How do I figure out the gear ratio? I can't seem the find any numbers or markings on it. What do I look at to figure out what kind and ratio it is?
Jay146992 is offline   Reply With Quote
Old 10-21-2010, 04:38 PM   #2
PapaBo
PapaBo's Avatar
Re: Help me identify my front end
looks like a 10 bolt, there is an old trick to finding the gear ratio by turning the wheels but i dont know the exact procedure, might be easiest to open it up and count the teeth or find the markings on the gears themselves
PapaBo is offline   Reply With Quote
Old 10-21-2010, 04:42 PM   #3
Cue-Ball
Cue-Ball's Avatar
You pretty much have to either open it up or do the "spin the wheel and count the driveshaft turns" methods to determine the gearing. Even if the axle were stamped with the factory gear ratio, these trucks are over 30 years old and lots of parts have been changed in that amount of time.
Cue-Ball is offline   Reply With Quote
Old 10-21-2010, 05:38 PM   #4
3r!c84
Badass
3r!c84's Avatar
what paint did you use on it? looks good
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 10-21-2010, 05:59 PM   #5
Jay146992
Jay146992's Avatar
I took the cover off of the diff and counted the ring and pition teeth. 43 divided by 14 right? It came out to 3.071. Does that sound right or didn't I count the right thing?
Old 10-21-2010, 06:49 PM   #6
78 Chevyrado
Dunno the exact number it should be, but you used the right math formula. Ring / Pinion=Ratio
78 Chevyrado is offline   Reply With Quote
Old 10-21-2010, 10:15 PM   #7
Jay146992
Jay146992's Avatar
Thanks, I used epoxy primer and paint called gloss black frame paint.
Here is some pictures of the whole chassis
Old 10-21-2010, 10:47 PM   #8
3r!c84
Badass
3r!c84's Avatar
got the brand of the paint? is it rattle can?
-00 Saturn 5spd
1/4:13:90
Old 10-21-2010, 10:59 PM   #9
Jay146992
Jay146992's Avatar
Here is the paint. I ordered it from tiptools.
http://www.tptools.com/Product.aspx?display_id=3073
Thread Tools
Display Modes
