10-21-2010, 05:32 PM | #1 |
Do I need to splice into my fuel guage wire ?
I have installed a rear tank with the sending unit in it and all grouded and a wire running through the firewall to under the dash .
I have a harness that carries the wires form the fuel guage to the fuse block . Not sure what wire is the fuel guage wire. I see there is a fuel guage plugin the fuse block but not sure what it is for . My question is this: What do I need to do to complete the hook up . thx as always if you can get me going on this .. Last edited by GOPAPA; 10-21-2010 at 06:07 PM. |
10-21-2010, 06:26 PM | #2 |
member #16
Re: Do I need to splice into my fuel guage wire ?
The fuel tank sending unit wire should plug in the fuse panel. The rest are internally in the loom and printed circuit.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
10-21-2010, 07:30 PM | #3 | |
What I have now is a 50/50 situation.. another guy said to hook it directly to the Guage..?? I looked at the wiring diagram but I dont see real well and cant read whats what or tell colors very well ,,so was hoping someone would just tell me step by step how to do it from what they learned in doing so.. and also thx for the this Url ,,it's full of help ideas.
When you learn a thing a day you store up smart. Last edited by GOPAPA; 10-21-2010 at 07:55 PM. |
10-21-2010, 09:02 PM | #4 |
Cruzin
i would seem to think hooking it up to the fusebox in the fuel gauge slot would be the right since it worked on the factory tank and will carry it to the gauge anyways ya know
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
10-21-2010, 09:23 PM | #5 |
You and John have to be right ,,what the heck would the plug be for at the fuse block.. if were not for the sending unit,,just wanted to get it right the first time I hooked it up..thx HubScrub,,
When you learn a thing a day you store up smart. |
10-22-2010, 10:17 PM | #6 |
Whats wrong with moving the origional wire out of the cab and extending it to the new sending unit??? Or is this in addition for more capacity??
Just a thought and what i had in mind but i didn't recive a harness.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
10-22-2010, 10:50 PM | #7 | |
now ,,it's extending the purple wire to the silinoid that was cut to short and figgering out what other wires that I need,,but this is another thing altogeather.. thx swamp rat I appeciate all the help I get on this..
10-23-2010, 01:40 PM | #8 |
Back in the sticks
Sorry, not sure if you've got the fuel guage figured out or not. Just ground the sending unit with the wire on it, run a new wire from the terminal on the top of it to the fuse box and you should be in business.
Only other thing you might want to check is the fuse in the fuse box for the instrument panel. My gas guage quit working and turned out I had blown the fuse. Now the gas guage and temp guage work.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Thread Tools | |
Display Modes | |
