Old 10-24-2010, 07:53 PM   #1
muckyp
muckyp's Avatar
Question Help me diagnose problem
Ok I have finally got to the point of starting my truck after it has sat for many years. I have had the truck about a year and a half and the PO said he and his son had been working on it for several years. It has a 454 with HEI. I have gotten it all rewired. It started up with out too much problem bit it won't stay running. After it runs for a couple of minutes it starts popping and then will backfire and die. It seems to prefer being choked a little. If i attempt to accelerate at all it will die. Any suggestions as to the problem?
muckyp is offline   Reply With Quote
Old 10-24-2010, 07:57 PM   #2
stich626
Re: Help me diagnose problem
blown powervalve.
stich626 is offline   Reply With Quote
Old 10-24-2010, 08:16 PM   #3
muckyp
muckyp's Avatar
Do Edelbrock carbs have power valves? But on that note I had a Holley on there first and then switched it out for an Edelbrock, with the same or at least very similar problems.
Old 10-24-2010, 08:40 PM   #4
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
HEI module gone bad would be my 1st guess
When the start to heat up the short out and die
Let it cool off and it will run again
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 10-24-2010, 09:09 PM   #5
muckyp
muckyp's Avatar
Thanks for the replies. It will start right back up if I choke it again. Does that still sound like HEI module?
Old 10-24-2010, 09:29 PM   #6
463
463's Avatar
i think i would start with a base timing check, check the vac advance with a vac pump for a leak down test , check the advance weights in the dis. the backfire is a timing thing in my books. how old is the fuel? are all the plug wires wired up correct? and never take any thing for granted when there has been others with there fingers on it.
Trueman
463 is offline   Reply With Quote
Old 10-24-2010, 09:32 PM   #7
pat 70/71
pat 70/71's Avatar
Might be running lean/low fuel pressure is my guess. change out the carb to a known good carb and see what happens. Plus check all electrical connections at the dizzy. Does it get real hot for the time it is running? Pretty sure Edelbrock afb type carbs don't have power valves. hope this helps. cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 10-24-2010, 10:01 PM   #8
muckyp
muckyp's Avatar
Thanks guys, I will take a second look at the wires and I am getting another carb tomorrow and hope for the best. Pat 70/71, I would say that it does get pretty warm pretty quick. I have not been able to run for very long, but it seems to warm up fairly quick.
Old 10-25-2010, 10:06 AM   #9
RustyParts
RustyParts's Avatar
Might want to check the fuel filter also.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 10-25-2010, 10:30 AM   #10
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Lightbulb Re: Help me diagnose problem
*** Yes. Remember this is an electrical module. they do go out from time to time.
*** Another good advise given.
**** Best advise I can give you is this. And take it as you like; try only one thing at a time. PERIOD!
*** More good suggestions. But just take it easy and troubleshoot ONE item at a time. ***
Good luck.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 10-25-2010, 11:04 AM   #11
dadsworktruck
I would be interested to know how old the fuel is, are the fuel lines in good order and is the pump in good condition...
dadsworktruck is offline   Reply With Quote
Old 10-25-2010, 11:05 AM   #12
Zeke's Garage
Zeke's Garage's Avatar
All the above mentioned items are well worth looking at, but it does sound a bit like a fuel delivery problem. Do you have a way to test fuel pressure from the pump?
Also double check your static timing. Set #1 cylinder to TDC, and verify that the harmonic balancer lines up with the marker, and that the rotor is pointing to #1 terminal... then check the firing order.
Good Luck!
Shawn
Zeke's Garage is offline   Reply With Quote
Old 10-25-2010, 11:09 AM   #13
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My first impression is a small vacuum leak. You mentioned that it started right up wihen you choke it. If the engine is warm, then that means it is getting air from somewhere besides the air horn. When it is running again, and the choke is off....put your hand over the air horn and limit the amount of air that the carb gets. If you can keep it running by keeping your hand over the carb....you have a vacuum leak somewhere. If it dies when you cover the air horn, you don't have a vacuum leak.
Since it has been some time since it ran, it wouldn't hurt to know that it doesn't have an intake leak. If you want to find out, spray some starter fluid (ether) along the intake to head gasket and see if the engine speeds up. If so, you know you have an intake gasket problem.
Member Nr. 2770
Old 10-31-2010, 12:48 AM   #14
muckyp
muckyp's Avatar
Just wanted to let you guys know the solution to my problem. I had the timing way off. Once I got the timing set it ran fine. Thanks for all the help. I should have it move under it's own power by next weekend.
Thread Tools
Display Modes
