Old 10-25-2010, 11:37 AM   #1
tanman722001
tanman722001's Avatar
Wipers
On my 72 GMC 3500.I have one one speed.The switch is for two speeds.What would claues it to only work on slow?Is it the switch or the wiper motor?thanks Tony
1991 GMC K2500 4X4 350/auto
1991 Chevy S10 ext cab.
1990 Chevy S10
1993 Chevy S10 Blazer 4dr 4.3 Vortex/Auto
tanman722001 is offline   Reply With Quote
Old 10-25-2010, 11:43 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Wipers
The wiper switch is easier to change.....my thinking is that if the wiper motor runs at all, it's probably okay.
Do the wipers only run on the first position or do you have to go to the second one? If it runs on the first position, but not the second, I vote switch.
But, on the outside chance that doesn't fix it, a wiper motor would be the next stop.
Member Nr. 2770
Old 10-25-2010, 11:48 AM   #3
tanman722001
Re: Wipers
It runs at the same speed on either position
1990 Chevy S10
Old 10-25-2010, 11:54 AM   #4
Irishpilot
Re: Wipers
I vote switch as well. When my wiper motor went out, it made a growling noise and the wipers did not move. Plus, go with the easiest thing to change out first. That would be the switch. The motor is kind of bulky and heavy.
Irishpilot is offline   Reply With Quote
Old 10-25-2010, 12:00 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Wipers
Plus, to get to the wiper motor you gotta be "agile and flexible". It's up behind the radio and attached with three nuts.
Member Nr. 2770
Old 10-25-2010, 01:33 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Wipers
see if this helps---------http://rmcavoy.freeshell.org/electrical.html
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-25-2010, 02:53 PM   #7
Putter
More Cowbell....
Putter's Avatar
Re: Wipers
If it runs only one speed, most likely it is HIGH. There are three wires on your switch. When these wires are grounded, things happen. Do this....pull the plug off the switch.
Then using a jumper wire, connect the wires in the harness to ground.
One will make the washer work. (should be the center wire)
Then ground the other two at the same time. This should create LOW speed.
Then remove the ground from the wire that is at the top (all by itself). Leaving the bottom wire grounded should switch the motor to HIGH speed.
Here is a link to a photo that might help a little...or make it worse?!?!?
CLICK ME
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Thread Tools
Display Modes
