Old 10-30-2010, 10:24 PM   #1
steppside69
steppside69's Avatar
vacuum brake booster
I recently bought a brake booster from a 1983 1/2 ton chevy truck, I recently was looking through the forum and didnt see anything on installing the brake booster. I was wondering if there was any alterations needed to fit a 69 chevy 1/2 ton? I was looking at the booster, Seen that I may have to drill out the top two holes to install properly? Has anyone run into this problem? Let me know what you think, Thanks Eric
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 11-01-2010, 07:53 PM   #2
brans72
Re: vacuum brake booster
Let me try to get you some picture of what I am doing so far but have not yet fully installed and tested it. Brandon
brans72 is offline   Reply With Quote
Old 11-02-2010, 12:52 AM   #3
Captainfab
60-66 Nut
If that booster setup doesn't work out for you, I have an alternative that will work.
http://www.67-72chevytrucks.com/vboa...d.php?t=347484
Old 11-02-2010, 11:39 AM   #4
robnolimit
robnolimit's Avatar
Mounting is easy, but you will need to drill out the upper two holes. The linkage to the pedal will need to be adjusted, and you will need to drill a hole in the pedal to connect the linkage to. Thats it.
robnolimit is offline   Reply With Quote
Old 11-03-2010, 08:24 PM   #5
steppside69
Brans72 Thanks for the help, hope it works out for you. Look forward to see the pics!
Captainfab I seen your bracket and looks sweet, will go that route if I dont like the stock bracket.
robnolimit I assume that you use the same holes on the bottom of the bracket? I was looking at the pics from other projects but not certain. Thanks Eric
Old 11-03-2010, 10:55 PM   #6
70C10Toejam
Hellasick
70C10Toejam's Avatar
Do you have an auto or manual tranny? If you have an auto, the later boosters with the standard bracket will hit the shift linkage and thus needs to be spaced out. This is how I did it:
auto tranny
If you have a manual, then you can mount the bracket to the firewall like this.
manual tranny
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 11-04-2010, 08:04 PM   #7
steppside69
70C10Toejam
Great write up, I have a auto so your pics and step by step instructions Thanks Eric
Old 11-04-2010, 11:30 PM   #8
70C10Toejam
Hellasick
Thank you. You are too kind. These are the reasons I love this board. Chances are someone somewhere has already done something and they are more than willing to share it. Hope it works for you.
At some point, I want to get one of the boosters that mount to the firewall and built my own bracket for it. But this works for now.
Thread Tools
Display Modes
