Old 10-31-2010, 11:57 AM   #1
brew8
Help identify axle
Can you help identify this axle, I think it's an Eaton, let me know what you think, popped an axle need a replacement,thanks, Larry
brew8 is offline   Reply With Quote
Old 10-31-2010, 01:29 PM   #2
Re: Help identify axle
It's identified as a Corporate HO52 or non-Dana is how GM books list parts.It is an Eaton center section.There's a guy selling shafts in the parts board right now.How'd you break that beast?
Old 10-31-2010, 03:41 PM   #3
b454rat
Looks like the 6 lug semi float version...
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 10-31-2010, 05:06 PM   #4
brew8
ea, It's 6 lug simi floating, must be very rare or from the 50's, too much skinny pedal is what did it in, bummer, I have a 10 bolt rear, I put new bearings in I guess I couid change the spring perches and use it but I have no Idea what to use for emergency brake cable I think mine on a 62 truck woulkd be too short, Thanks, Larry
Old 10-31-2010, 05:12 PM   #5
desertrat
desertrat's Avatar
I have never came across a 6 lug version before what trucks did they come in?
"Men are like steel. When they lose their temper, they lose their worth." — Chuck Norris
desertrat is offline   Reply With Quote
Old 10-31-2010, 05:19 PM   #6
b454rat
There *was* one in my 62 burb 4x4. I'm guessing early 60s...
Old 10-31-2010, 05:23 PM   #7
I went by the first picture.I thought that was a different axle on the floor jack.Now I see the flange on the axle shaft has 6 studs and it is a semi-floater to boot.Good eye Rat.That will be a hard one to find.It would be nice to replace with a 14-bolt 6-lug semi-floater.But,you already have the 10-bolt.
what truck is that under?Is it a Napco?
Old 10-31-2010, 05:46 PM   #8
brew8
It's a 62 SWB fleet side K10
Old 10-31-2010, 08:50 PM   #9
That would be the same axle as the 50s.I asked Napco because the rear would be the corporate 2wd.
Old 11-01-2010, 12:44 AM   #10
raycow
That's the normal 1/2 ton rear used 55-62. Some people call it an Eaton, but it was actually made by GM. I believe the GM designation is either H033 or H035.
My 60 C-10 has basically the same rear, except with brackets for the trailing arm supension. The most common ratio is 3.90, but they were also made with 4.11 and 3.38, the last being quite scarce.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 12-20-2010, 11:15 PM   #11
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I'm not trying to hijack this thread....
I just don't see the sense in 10 different threads asking the same question.
So,
Could somebody identify this front axle?
it's on a 1979 1/2-Ton Chevy Suburban.
66 C20 Service Truck:
Old 12-20-2010, 11:21 PM   #12
brew8
GM 10 bolt
Old 12-21-2010, 08:20 PM   #13
LostMy65
LostMy65's Avatar
^Thanks.
If it is safe to assume the front gear ratio is the same as the back, then is a 3:40 a good ratio?
--see pic--
Old 12-21-2010, 10:49 PM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Depends on what you're doing with the truck.... for a fairly stock street-driven truck, 3.40 is a good all-around compromise. Low enough to give you decent acceleration, low-end grunt, and towing power -- and high enough to be driven at highway speeds. Not too bad for fuel mileage either, but that's kind of a moot point on most of these trucks anyway.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Thread Tools
Display Modes
