Old 11-04-2010, 10:15 AM   #1
MB_70
52" leaf spring swap
Is this swap really worth the time and effort involved?
Does this swap provide a better ride on the highway iin comparison to the 4" lift kits that are available?
I assume it doesnt effect towing abilities too much as well?
Im looking into this modification for the benefit of "free lift" without sacrificing ride quality. Do you gain any lift by doing this swap?
Do you have to move all 8 spring pockets, or just 4 of them to accomidate?
I have a stock 1970 K-5 that will be getting a 427 and a TH700R4 swapped in as soon as I get home from overseas.
Eventually, I want to go to 3/4 ton axles, and 35 - 37" tires. I figure this is a nice was to set my rig up for that.
I plan to use my Blazer for mild off roading and back roads with some occasional towing inbetween.
MB_70 is offline   Reply With Quote
Old 11-09-2010, 07:28 PM   #2
63chevyll
gets board easy.......
63chevyll's Avatar
Re: 56" leaf spring swap
free bump
63chevyll is offline   Reply With Quote
Old 11-10-2010, 01:51 AM   #3
'63GENIII
'63GENIII's Avatar
I haven't done the swap myself but I am setting to do the 63" rears with 52" fronts to try to get a better ride yet still maintain tow / haul capabilities. I may use a shackle flip in the rear for the 63"ers. I have heard that it does change the ride to a flexier one.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 11-10-2010, 02:19 AM   #4
vk_chevy
vk_chevy's Avatar
There are some posts about doing this swap but I don't recall seeing a "how-to" or a comprehensive guide on the subject. Perhaps it's a real easy job but even info from vendors that sell parts for these swaps seems to be lacking.
From what I understand, doing the 52's will net you around 4-5 inches of lift based on what springs you use.
I am about to resurrect my my old 4x4 3/4 build and this is the route that I'll be taking as well. I think our objectives are very similar as far as the lift and tires go. I have many ideas for the engine/trans/transfer but most likely will be sticking to the stock 350/350/205. My main concerns are steering and pinion angles as I lack knowledge in drive train department. I got a few things to finish up before my truck goes into the garage and hopefully I'll be able to start on it in about a month or so.
72 Chevy C20 Longhorn
72 Chevy, K20 Custom Camper
67 Chevy, LWB, C20, 350/350, PS, PB,
65 Jag MKII
vk_chevy is offline   Reply With Quote
Old 11-11-2010, 01:27 AM   #5
Captainfab
60-66 Nut
There is a lot of info on this swap over here....http://www.coloradok5.com
You can purchase the necessary conversion brackets and rear shackle flip from Kert at DIY4X
http://www.diy4x.com
Kert is a very nice and helpful guy to deal with.
Old 11-11-2010, 07:37 AM   #6
Is the question about 56" on the rear or front?
Old 11-11-2010, 08:21 PM   #7
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
If for the rear, I think they are worth it. I mainly swapped to 56’ rear springs to increase the load capacity as well as the added flexibility. The truck actually does ride better too (but that could have been the shackle flip) and I can haul more crap in the back without it sagging so badly. I grabbed 56” rear springs from a LWB ¾ ton 4x4.
Here is the thread from my install.
http://67-72chevytrucks.com/vboard/s...d.php?t=345632
Flex pictures from our Canyonlands trip this past summer.
DirtyLarry is offline   Reply With Quote
Old 11-12-2010, 08:54 AM   #8
I have 4" EZ-rides from a '91 Suburban (56") and I want to put them under an '85 Jimmy.But,this will change the ride height,right?I don't want it any higher,so I'm thinking maybe I'll do a shackle flip with original springs instead.Just wanted to use what I have if I could.
Thread Tools
Display Modes
