11-07-2010, 06:20 PM | #1 |
Install Time
I was just wondering how long would it take to install a complete MII kit triangulated 4 link with Notch and engine and trans mounts.
11-09-2010, 03:38 AM | #2 |
Re: Install Time
'm going on three months but I only get about 15 hours a week since the place it's at is only open two days a week.
1958 Fleetside shortbox 1965 Malibu SS 1970 Camaro RS 1972 Malibu wagon |
11-09-2010, 01:39 PM | #3 | |
Re: Install Time
Justin www.scottshotrods.com |
11-09-2010, 03:21 PM | #4 | |
Re: Install Time
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
11-09-2010, 03:32 PM | #5 | |
Re: Install Time
sheetmetal off the truck. We would mark your center line of your front suspenion and remove all stock suspnsion off the frame in the front including steering box and leaf spring hangers.We weld up all holes from firewall forward and then box in front part of your frame.Weld up 100% and grind down to a clean metal finish. Then install front suspension and tig weld in place not MIG WELDED.Then your front is done. On the rear suspension mark centerline of rear axle.Then remove all stock suspenion and box in rear frame section for strength and weld up 100% and metal finish out.On your rearend you supply we would remove all factory brackets on rearend and clean off 100% then install new 4-bar brackets and tig weld on.Install your shock crossmember and install all rear suspension onto rear part of your frame.Install your c knotch or step knotch. Justin www.scottshotrods.com |
11-09-2010, 05:21 PM | #6 |
Moderator
Re: Install Time
I had more time in removing the old crap than fitting and installing the new. If you're taking it to a shop and want to save some labor do the dirty work yourself for sure. Once the frame is clean it's gravy.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
11-09-2010, 07:33 PM | #7 |
Re: Install Time
If your not going to do it all yourself you better let the shop that is installing the front/rear end mark their own axle centerline. that way if its jacked up they cant blame you
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
11-09-2010, 08:50 PM | #8 |
Re: Install Time
I'm having a shop do the install. I just wanted to know how long it should take. The engine and trans is out of the truck. In those two says how many hours total and how many guys?
11-09-2010, 09:30 PM | #9 |
Re: Install Time
I would never ever ever ever set a new crossmember in with out the front sheet metal on the truck.
I'd remove all the stock suspension, clean the frame, align both front fenders and hood, mark the CL with some plumb bobs(make sure truck is level is all directions!), then remove the sheetmetal, make sure the CL marks are perfectly square, and put the crossmember in. and if your bagging it to lay it out put it about .25-.5 inch in front of the CL marked so the wheels are closer to center laid out. or maybe Im OCD? |
Thread Tools | |
Display Modes | |
