Old 11-07-2010, 07:27 PM   #1
ffk
ffk's Avatar
looking for photos of your dropped trucks
hey im thinking about going with a 2 1/2 -4 drop or 3 1/2 -5 drop in back.on my 68 shortbed c-10.dont know if im going to run 18's or 20's..can you post some photos..im going to run stock inner fender walls.....im just looking for some ideas for next spring..thanks
ffk is offline   Reply With Quote
Old 11-07-2010, 07:54 PM   #2
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: looking for photos of your dropped trucks
Have a look through this thread.
http://67-72chevytrucks.com/vboard/s...lowered+bagged
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 11-07-2010, 08:04 PM   #3
breezy
3 inch belltech spindles and 96 ford taurus rear station wagon springs.
rear dropped 4.5-5 18 inch coy wheels. I'd like to go another inch but this was a quicky deal to get the truck rolling lower.
breezy is offline   Reply With Quote
Old 11-07-2010, 08:20 PM   #4
dmwphoto
dmwphoto's Avatar
before
after an Early Classic enterprises 3 1/2 - 4 drop (2 1/2 drop spindles, 1" drop coil and shocks up front, 4" drop coil in rear with shocks, super trak bar and shock relocators. Actual drop in rear ended up being 5".
dmwphoto is offline   Reply With Quote
Old 11-07-2010, 08:38 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
You only asked for 2.5/4 and 3.5/5, but you might as well check out all your options...
4.5/6" ECE Drop, 6-lug disc brake upgrade, 20x8.5 and 20x10 SL Vintecs
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-07-2010, 11:20 PM   #6
Zoomin
Man of Mini-Talents
Zoomin's Avatar
3.5 / 5
Zoomin is offline   Reply With Quote
Old 11-08-2010, 12:45 AM   #7
robzilla
robzilla's Avatar
Originally Posted by Zoomin View Post
3.5 / 5
what rim/tire sizes you running on yours? i like the stance.
robzilla is offline   Reply With Quote
Old 11-08-2010, 09:39 AM   #8
68Stepbed
68Stepbed's Avatar
3.5/5 with 17's
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-08-2010, 12:07 PM   #9
Zoomin
Man of Mini-Talents
Zoomin's Avatar
18's all the way around. 255/45 and 275/45 on 8's and 9.5's
Old 11-08-2010, 01:02 PM   #10
big_al_71
big_al_71's Avatar
4/6 drop ECE stuff with 18/20 combo
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-08-2010, 01:28 PM   #11
406 Q-ship
406 Q-ship's Avatar
I am looking at a 3.5/4 or a 5" rear drop. I would like to get responce from those that dropped the rear 5", did you have to notch the frame and if not how much clearance from the top of the axle to the frame. In my measuring I come up that a 4" will give my 2 3/4" gap between the axle and the frame.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 11-08-2010, 05:36 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
No notch required for a 5" or a 6" drop; unless you will be doing heavier than normal hauling/towing.
With a 6" drop I had 2" between the fram and the top of the axle to the 4" between the top of the pumpkin and the bottom of the bed; IIRC. Have only bottomed out once... and I was pushing it down the road pretty good. I'll recheck my measurements tonight.
-Nate
Old 11-08-2010, 09:11 PM   #13
Robertjust777
Robertjust777 is offline   Reply With Quote
Old 11-17-2010, 12:20 AM   #14
71Tymbomb
71Tymbomb's Avatar
My 71 before and after. Brothers performance package. 2" drop spindles 2" drop springs up front, out back 4" drop springs plus 2" blocks, sway bars, performance shocks, and sway bars all around.
71Tymbomb is offline   Reply With Quote
Old 11-17-2010, 01:11 AM   #15
Ole Greenie
Ole Greenie's Avatar
Here are a couple of my before and after shots. I lowered it just last week. 2.5" drop spindles and 1" lowering springs with 4" rear drop springs.
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773
Ole Greenie is offline   Reply With Quote
Thread Tools
Display Modes
