I dun gradjiated collij!!!
Lil 307 that could....
So the valve guides on my 307 are shot...blows smoke after I crank 'er up for a few. Lifters are tapping as well so I figured I would gather up some of my spare parts from other builds and hop up my little "boat anchor"
![]() Combine these ingredients...shake...stir... and see what happens: Short block is my '71 307 sporting flat top 4VR pistons @ .025 in the hole, no ridge and decent oil pressure so I'll run 'er as is. Bone stock set of Vortec 906 castings that have been rebuilt to stock specs, nothing done but tanked, valve job, and new seals. I also have a Summit stage 1 Vortec intake (Performer knock-off) that is needed for the Vortec head swap. A Summit K1103 cam kit 214/224 @.050 and just enough lift to stay safe with the Vortecs A Cloyes double roller chain set at 0 degrees I'll re-use my Eddy 1406 as it is in great shape. My goal is to build up this little 307 and eventually swap it into the wife’s Malibu.... Desktop Dyno 2003 shows this combo will pull ~350/350.... We will see.... ![]()
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! Last edited by screamin_c10; 11-07-2010 at 11:26 PM. |
Cruzin
Re: Lil 307 that could....
good luck, i like the little motors they get so much hate
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
307 is the only motor that lived more than 2 weeks below my buddies 6-71 blower in his 71 pro-street.. blew up a 383 and 350 in 2 weeks time... the 307 was a RUNNER !!
Starting Point:
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! |
That sounds good!I built a hot little 307 once on a budget.It needed no machining...and I had it hot tanked and checked it out.They seem to hold up really well.The timing chain had gone out and the valves bent.I put .194 350 heads,RV cam/lifters,stock 4bbl intake,little 450cfm Holley,HEI,dbl row timing chain,bearings,rings...the thing ran out like a healthy 350 my K/20 with 37" tires and 4.57 gears.It was a work truck and carried a lot of weight.The best thing was,not only was it peppy but it got 13+ mpg.I'd like to see what Vortec heads would do for a small mouse.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-08-2010 at 02:55 PM. |
One thing I have always found fascinating is how fast people dismiss the 307 as a viable street motor... If you are looking for a good cruiser with decent gas mileage and a little bit of balls then why not build what ya got? I guess its easier to toss it if its worn out and replace it with a crate engine but where is the fun in that....
Just the other day I was getting fuel when a guy comes over talkin' about what a cool truck "sounds mean is it a big block?"... Once it sunk in that it was a 307 he looked a bit disappointed....I thanked him for the compliments, paid for my gas, idled out to hwy 30 and destroyed my back tires til I let up at 45.... ![]() But those days are over for this lil mouse, once I get her built, running and tuned I'll be dropping her into the wife's Chevelle to live out the remainder of its days under a slightly less aggressive right foot ![]()
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! Last edited by screamin_c10; 12-08-2010 at 06:34 PM. |
![]() Join Date: Jan 2009
nothing wrong with a 307. glad to hear you showing it some love
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
Well for such a wimpy little mouse she's putting up one hell of a fight....First off the damn exhaust manifold bolts decided to seize up in the ramhorns necessitating a sawzall and a few "colorful" words of persuasion to aid in their removal. Now the studs at the pipe flange gave up with no issues, yup snapped right off
![]() ![]() On the flipside the bores look awesome for 40 years old, no ridge or scoring. My plugs were a nice tan color, oil pressure was good so I'm cool leaving the shortblock as is. Ordered up some .021 steel shim gaskets so my quench will be right at .046 with a SCR of 9.0:1, very pump gas friendly. ![]() Obviously If I am going to go to the expense of machining and building a new shortblock it will be a roller 355/383 880 block. I just want to see what this lil mouse can do on a serious budget.
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! Last edited by screamin_c10; 11-12-2010 at 04:28 AM. |
Well the Vortecs are on the 307, new cam installed, rockers adjusted, intake on, HEI stabbed, chain and sprockets set to 0 TDC, carb and wiring hooked up.
Just need to pop on the timing cover, plugs and wires, w/p and accessories. The ramhorns are in pretty bad shape, still trying to figure out how to get the studs out so I can run them for now. Gonna go to headers and a 2.5 dual system once spring rolls around.... Its gettin' down right cold here, if the weather allows I should be able to crank 'er up next weekend.... ![]() Spent a couple hours in the warm shop doing the jeep fan upgrade as well. Came out pretty good if you ask me.
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! Last edited by screamin_c10; 11-19-2010 at 11:02 PM. |
Cruzin
very nice
Looking forward to how she turns out - looks great so far.
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" ![]() ![]() |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yes I agree that the 307's have gotten an undeserved bad rep. The guy that first showed me how to build a small block had a well built 307 in his Jeep. 11-1, 2.02/461 heads, good sized solid lifter cam, etc. That thing was pretty impressive. I've been around a couple other mildly built 307's since. I've actually given some thought to building one my self......I've got a short block in the shop. I'll be watching this thread to see how this one turns out.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 11-20-2010 at 12:22 AM. |
#13 |
Done...well almost, still need to hook up the exhaust to the ramhorns and swap in the temp sensor from the old heads...plan on crankin' her up in the a.m. it got too darn cold to mess with her much more tonight...
#14 |
As soon as I scrounge up a serpentine crank pulley I'll be swapping over to the same setup I have on the Chevelle....hence the un-painted nasty brackets...
#15 |
Registered Chevy Owner
Good to know that an ol' lil' 307 is a great engine. I'm gonna build one up for my '51. I was just going to put a set of 305 601 casting heads on it. That should give me just a little bit more compression
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
#16 |
60-66 Nut
Oh! the anticipation
![]() Are you guys getting that Arctic air over there too?
#17 |
Grandpa in the rustmobile...
hey man, i see your runnin centerbolt VC's too..
My bolts leak oil around the head? do yours have a lil rubber seal or anthing?.. other than that looks good dude! i didnt know you coudl put vortecs on other engines too
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#18 |
Looks good. Waiting to hear how it runs.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#19 |
Big Red - Now its a SWB!
I'm waiting to see how it runs!
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 11-21-2010 at 02:24 AM. |
#20 |
My natural tendency is to root for the underdog! I'm anxious to hear how this one turns out.
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
#21 |
Cruzin
#22 |
Yup, its gettin' down right nippley...
#23 | ||
I would never pull them out through the top.....and I wish they would quit selling those rediculous tools for doing it. All it does is destroy the inside of the lifter bore, which causes oil pressure issues. Then comes the other thing, what was keeping them from coming out? If it was just carbon/gunk build-up, it's not so bad, except that is probably everywhere inside the engine. If it is from a metal burr....that comes from wear against the cam...and that means metal particles have coated everything inside and tears up the bores even worse. Neither of these is good for a new cam installation. I wish I had seen this a few weeks ago...
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#24 |
It was crud / carbon build up on the lifters. The original cam had 3 flat lobes so I know the engine is nearing the end of the line. If it lunches then I will be building a mild roller 350 and laying to rest my beloved ol' 307. Basically this is a "will it work?" type of build.
If it fails I'm out $120.00 bucks for cam and head gaskets. But I least I can say I tried it and it was a blast while she lasted... ![]() Now mind you this engine ran smooth as glass and idled @ 700rpms. Blew no smoke other than fire up and made no noise with great oil pressure. HOW? I have no idea...three flat lobes at least 2 different brand lifters, Huge slop in the T/C and an almost completely restricted passenger side ram horn. Still boiled the tires and was a blast to drive, hence her name "Screamin'" I'm gonna let 'er go out in a blaze of glory...either today or down the road when she finally gives up the ghost... ![]()
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! Last edited by screamin_c10; 11-21-2010 at 04:44 PM. |
#25 |
I'll bet that thing will keep on runnin' like a champ, and you'll never break it
Thread Tools | |
Display Modes | |
