11-08-2010, 11:42 PM | #1 |
Junior Member
'70 1 ton disk brakes
I have a '70 C30 cab/chassis w/a Franklin motorhome on the frame, don't use it as much as I like cause of the drums. Decided that I am going to put disks on the front this winter. Been doing a quite a bit of reading and sounds like purchasing a complete cross member from a '73 - 87 C30/C20 and rebuilding it as necessary, would be the way to go. Read somewhere that the dually fronts were a little wider to match the rears, would getting a front off a C20 matter that much ? Would like to lower it a bit but doesnt seem that their is much out their and don't think I want to go the cost to bag it. So swapping out crossmembers sounds like the way to go. Any input on lowering or anything concerning this project would be appreciated.
'71 C10, Choptop/Lowered '70 C30, w/24' Franklin Motor '91 9c1 Caprice '90 Harley FL, 127 Ultima engine w/6 speed, Blk & chrome |
11-09-2010, 09:18 AM | #2 |
Re: '70 1 ton disk brakes
You could swap the entire x-member from a later C30 or just swap the parts to your existing x-member. C20 stuff is the same w/o the Xtra HD brake hub/rotor.
Lowering the front is simple if swapping the parts. Western Chassis & Bell Tech offer 3" drop spindles that give you the drop w/o compromising ride quality or geometry vs. stock height.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-09-2010 at 09:18 AM. |
11-09-2010, 07:30 PM | #3 |
Junior Member
I am kind of leaning towards swapping x members, have been watching Craigs list, havn't checked out any salvage yards yet, for later model C30/C20's, acouple on their now w/454's and turbo 400's in the $1,000 range, has a 350 now, a little xtra power would be great, thanks for your reply. Do you have an idea of what a person could expect to pay for a x member ?
11-09-2010, 07:51 PM | #4 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-09-2010 at 07:53 PM. |
11-09-2010, 08:44 PM | #5 | |
Junior Member
Thread Tools | |
Display Modes | |
