11-09-2010, 02:09 AM | #1 |
Carpet install
I 'am getting ready to put carpet in my truck& a friend asked me if it needed to be glud down or something else. I had not thought about it and don't know, can someone please answer this for me .THANKS MIKE
11-09-2010, 09:36 AM | #2 |
Re: Carpet install
The carpet doesn't get glued down. However the jute backing or sound deadener does.
Then you put the carpet over it. Are you using a carpet that's moulded to fit? |
11-09-2010, 10:37 AM | #3 |
Re: Carpet install
I got the carpet kit from Jim Carter in January. Its nice, but it's going to be larger than your cab. so, have a good box cutter on hand and a few replacement blades. I put down sound deadener as well. It makes a world of difference if you want a quieter ride. I didnt glue the carpet down because you might have to get into the trans tunnel for something. It would be a shame to ruin good carpet for something like that.
i got "fat mat" deadener. its cheaper than the name-brand stuff. a lot cheaper.
'64 Corvair Ragtop '66 C10 Stepside "The oxen may be slow, but the Earth is patient" |
11-09-2010, 11:46 AM | #4 |
Re: Carpet install
THANKS,This is what I thougt but didn't know for shure.I got carpet from STOCK INTERIORS, it's fitted and I see what your saying about the box knives.I've already put down sound deadner, now for the carprt. AGAIN THANKS MIKE
11-09-2010, 03:05 PM | #5 |
Re: Carpet install
How far under your seat does the carpet go?
11-11-2010, 02:46 PM | #6 |
Re: Carpet install
The carpet goes back to the gas tank,would go to back of cab if you pulled the tank.
11-11-2010, 04:47 PM | #7 |
Re: Carpet install
Thanks mikie
11-11-2010, 05:37 PM | #8 |
Re: Carpet install
may I recommend doing the peel and seal before you do it. I did it and it makes a big difference. I have that, then the underlay stuff and then the carpet.
Cheers David 66 LWB Fleet (on hold) 64 LWB Fleet (daily driver) 65 SWB Fleet (almost finished as a driver) 64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck) Nothing worth doing, is easy. Last edited by irish1966; 11-11-2010 at 05:37 PM. |
11-11-2010, 09:29 PM | #9 |
Re: Carpet install
3M makes a spray adhesive that works great for that. I didn't glue mine down quite yet, but I will after paint...
66' Chevy SWB:350ci-th350,frt. disc brakes, pwr steering, 5-lug waltshow.com/Chevy |
11-12-2010, 12:53 AM | #10 |
Redneck Hillbilly
Re: Carpet install
^^^I've always had great results using this method. I think the "Fat Mat" is a "peel and seal" type insulator as well.
11-12-2010, 01:19 AM | #11 |
Re: Carpet install
I got the peel & seel from ebay about $75 to do my truck with alot left. Works better when it's warm out, doesn't stick good if it's cold but not to hard to do.
11-12-2010, 10:19 PM | #12 |
Re: Carpet install
i have used auto custom carpets for many years http://www.accmats.com/ and they also offer kick panels,door panels as well as rear cab wall carpets and sound deadening mats custom molded to fit our trucks and even bed carpet for you stepside guys
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
09-23-2012, 10:18 AM | #13 |
Re: Carpet install
Looking for help, I am installing gas pedal "with carpet". She is a 1965 c10. My question is how to cut the carpet; is it "cut just around the pedal studs", or is it "cut a slit between the studs", then slip th lower flat portion of the pedal under the carpet through that slit?
Posted via Mobile Device |
09-23-2012, 01:04 PM | #14 |
meowMEOWmeowMEOW
Re: Carpet install
I didn't keep the stock gas pedal since my truck is DBW, but when I put carpet in...the pedal stud could unscrew from the floor. I'm not sure if thats normal, but if so I'd think it would be easiest to just use a ice pic to find the hole, then cut a small X with a knife and see if you can fit the stud in there.
09-23-2012, 01:30 PM | #15 |
Re: Carpet install
Thanks for the reply, I had not thought of screwing the studs back down onto the carpet! Great idea, might put some washers under them to help hold the carpet down better too, I'll give it a try, and let you know
09-24-2012, 06:03 AM | #16 |
Re: Carpet install
I ended up just removing a bit of the jute padding on the carpets backside at the pedals location. I have sound-deadening material down, so it was too thick at the pedal site. Problem solved!
03-20-2013, 06:21 PM | #17 |
Re: Carpet install
How far to the firewall does the carpet go? Does it go over, or under the rubber/jute firewall pad?
Thank you. Tom |
03-20-2013, 08:25 PM | #18 |
meowMEOWmeowMEOW
Re: Carpet install
Only goes about half way up the fire wall, where the floor stops angling into the firewall. Mine overlaps the jute.
03-21-2013, 08:49 AM | #19 |
Re: Carpet install
Any pics?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Thread Tools | |
Display Modes | |
