11-09-2010, 09:45 AM | #1 |
SBC to BBC clutch differences? Z-bar??
I'm thinking of going from small block to big block in my 4 speed 1 ton. Are there any differences in the engine pivot ball, Z-bar or other clutch related parts? Thanks.
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
11-09-2010, 10:53 AM | #2 |
Junior Member
Re: SBC to BBC clutch differences? Z-bar??
My '71 C-10 came with a 350 and granny type 4 speed. When we put the '73 454 in it I bought a pivot ball for it from Napa/Auto Tire and Parts #65-1197 for a little over $10. The one for the 454 screws in the block.
We used the rest of the clutch linkage stuff from the 350 set-up. I have heard some have had to shorten the Z-bar, but in my case we did not.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
11-09-2010, 09:26 PM | #3 |
You can use most of the small block parts if you use the small block motor mounts and stands. If you use big block mounts and stands you need the bracket for the z-bar, the z-bar and the pushrod through the firewall.
Thread Tools | |
Display Modes | |
