Bottom of heater motor ?
Looked at heater pics on the board but couldn't find what i was looking for. On my heater box in the engine bay i have 4 bolts that extend off the blower motor. What attaches to that or does anything? Was there some sort of motor cover for the blower or something i am missing? thx
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
Re: Bottom of heater motor ?
Can you post pics? I don't see anything sticking off the end of ours.
Senior Enthusiast
I've never seen a cover on these. It sounds like someone may have replaced the motor and simply used non-original extra long screws.
I just replaced mine with one from Napa. It had two bolts that stuck out of the motor about 1". They actually hold the motor together. Is that what you're talking about?
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
I'll take some pics when i get home this evening. They are threaded like something attaches to them.
here is the pic, maybe that is just how it is but it seems something is missing especially with the seal up against the bottom of the fan.
60-66 Nut
![]() ![]() Join Date: Mar 2007
From what I can see of it, that doesn't look like the correct fan motor.
I would agree. I don't recall having any foam like that on any of the three trucks I've had. Mine have all mounted with sheetmetal screws too.
It mounts with sheet metal screws also. It works so i suppose i will just use it until it goes out. No telling, i have found some interesting stuff on this truck from previous owner. Just a little hideous looking. thx guys..
Thread Tools | |
Display Modes | |
