Old 11-13-2010, 01:20 PM   #1
vtwinsport
vtwinsport's Avatar
Read my head and valves
Hey all,
What does this set of heads tell you about the combustion?
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 11-13-2010, 02:09 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: Read my head and valves
That white area in the CC an indication of a leaky head gasket ?
Malo83 is offline   Reply With Quote
Old 11-13-2010, 02:34 PM   #3
cableguy0
Any pictures of the gasket itself? It looks like you were running lean.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-13-2010, 02:38 PM   #4
vtwinsport
vtwinsport's Avatar
none of the gasket. didn't have any oil in the anti freeze when I changed it at the same time. I was told my valve guides are worn out on #5 & 6
Old 11-13-2010, 05:19 PM   #5
Restrorob
The One And Only !!!
Restrorob's Avatar
I agree with cableguy..... A quick smack on the valve spring with a deep socket will pop the keepers out so you can remove the spring, Then see if the valve wiggles in the guide. It seems odd that only those two guides would be worn.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 11-13-2010, 07:02 PM   #6
PRattenbury
Yeah, either lean condition or burning antifreeze.
PRattenbury is offline   Reply With Quote
Old 11-14-2010, 01:08 PM   #7
vtwinsport
vtwinsport's Avatar
Yes, that's what I kept thinking so I put a new head gasket on when these went back in. I did do a valve movement test when the heads were out. There was very very small movement. I didn't have a dial indicator to measure the side to side play in the guide so I put them back in because a vacuum test before they came out didn't show any indication of sticky valves or valves leaking.
The # 5&6 plugs are still being ash fouled just like before the new head gasket when on so I'm thinking the valve guides are worn and or the heads are cracked.
I guess I'll pull them and take them to a block shop for inspection.
thx all
Old 11-14-2010, 02:00 PM   #8
PRattenbury
Did you make totally sure you don't have a vacuum leak anywhere, and fattening up the mixture??? It's really common to get vacuum leaks at the intake and carb gaskets.
Old 11-14-2010, 03:18 PM   #9
vtwinsport
vtwinsport's Avatar
Yes, I sprayed carb cleaner all around the intake, carb, brake booster and vacuum lines. I didn't get any change in idle when I did this. The exhaust valves do look like they've been running lean as they're so white.
I'm not sure what else to check so I think taking the heads to the block shop is the next step. The mystery though is if I am burning coolant in 5 & 6, why there is no coolant slick in my oil.
Thanks for the comments
Old 11-14-2010, 05:41 PM   #10
PRattenbury
It's possible to have a failure that allows coolant into the combustion chamber and not the crank case. It just looks like all cylinders were running lean to some degree.
Old 11-15-2010, 10:27 AM   #11
vtwinsport
vtwinsport's Avatar
I am not sure what would be making all the cylinders run lean. I adjusted the idle screws to maximum vacuum and then in (rich) a 1/2 turn. Timing is at 10 degrees and it seems to run great at all these settings.
Well, pulling the heads this time will tell me if all cylinders are running lean still.
thanks for the feedback.
Old 11-15-2010, 02:10 PM   #12
PRattenbury
Turning the screws in is not rich. That would be lean. Backing the screws out makes the mixture richer. If you turn the screws all the way in you will shut all the gas off and the engine will die. Give it a try.
Old 11-15-2010, 09:19 PM   #13
vtwinsport
vtwinsport's Avatar
oops, that doesn't help making it lean. thx.
Machine shop told me the exhaust valve seats were cracked and that there is a hairline crack at 5 & 6 causing the coolant leak at these locations. I guess this is common on older heads because the exhaust valves on 3 & 5 and 4 & 6 are side by side and they really cook right there.
Time to upgrade to aluminum heads.
Thanks all.
Thread Tools
Display Modes
