Old 03-03-2003, 08:38 PM   #1
Alexis
Member since 2000
Alexis's Avatar
torque converter bolts???
What bolts do you guys use? thanks
Alexis is offline   Reply With Quote
Old 03-03-2003, 08:52 PM   #2
RUDEDAWG
RUDEDAWG's Avatar
crank shaft bolts. I use arp. and on the flywheel I use grade 8 3/8" Aint broke nuthin' Yet.
'72 1/2 ton short box
468 BB forged crank/rods/pistons full roller. Msd 6 AL ignition
turbo 400 tci. 2800 verter
ladderbar/coil rear with currie built ford 9'' rear, 4.11 gears
custom built rear frame
tubbed, 33/19.50/15 rear m/t.
m/t skinnies in front
still under construction
RUDEDAWG is offline   Reply With Quote
Old 03-03-2003, 11:18 PM   #3
bigjimzlll
bigjimzlll's Avatar
ARP
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 03-03-2003, 11:42 PM   #4
COBALT
COBALT's Avatar
I agree. ARP even makes ones with irregular heads for externally balanced engines - in case you have a troublesome big block or a 400.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 03-03-2003, 11:57 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'm in the minority here I guess...I have stock bolts.
Old 03-04-2003, 01:07 AM   #6
bigjimzlll
bigjimzlll's Avatar
stock bolts are fine, as long as their new...bolts will stretch and get weak if tightend and re tightend...so instead of buying stockers..I go for the ARP, just because their a little stronger
Anderson,CA
Old 03-04-2003, 01:16 AM   #7
Project1970
14.1 @ 96MPH
Project1970's Avatar
I use stock GM bolts...mine are new, but that's namely because my 700R4's converter uses metric bolts.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Thread Tools
Display Modes
