11-15-2010, 07:35 PM | #1 |
Radios!
Hey guys, I was wondering what type of radio you are putting in your trucks? I am looking into them and don't really know whats out there. Also have you heard of a Highliner? Thanks
1972 Chevy 3/4 Ton 4x4 2001 Chevy Duramax 3/4 Ton 4x4 1972 Chevy Nova 468 BBC 1944 International K-11 1965 Chevy C-10 |
11-15-2010, 08:11 PM | #2 |
Re: Radios!
I've got a 15-yr old kenwood tape deck in mine. Oh YEAH!
But seriously, I plan on getting a stock am/fm radio when I get some $.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
11-15-2010, 08:22 PM | #3 |
Re: Radios!
Here's what I'm running in the 68 panel. AM and 8 track. Best of both worlds.
11-15-2010, 08:32 PM | #4 |
Re: Radios!
Google is your friend:
A Lot of these radios are set up to plug your MP3 into them, plus rca connectors for amps ect. http://www.retrosoundusa.com/products/category/id/10 http://www.soundmove.com/customautosound.htm http://vintagevibes.net/ http://www.bobsclassicchevy.com/cust...vy-radios.html http://www.vintageautoradio.com/
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-15-2010, 10:49 PM | #5 |
Sofa King Crazy!!
Re: Radios!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
11-15-2010, 11:39 PM | #6 |
Re: Radios!
I just installed one with a DVD player, it also takes SD cards, CDs and has Bluetooth so my cell automatically links up when I get a call. It has a 5.5" motorized screen. I paid only $200 for it and have had it about two months now and it still works perfect. I recently hooked up rear view camera that automatically turns on when I put the truck in reverse. I have an ipod dock that displays the coverflow from my ipod on the screen and has its own remote, I can look through 400 CDs on my ipod and pick any one of them easily. I love it!
I mounted two ten inch subs in sealed boxes under the seat, a 6 inch midrange in each door and a 1.25" tweeter mounted the the dash just above my AC vents. I mounted three amps in the pocket behind the passenger seat. It sounds excellent. Here is a pic of my cheap DVD,monitor. You can see the view from my rear view camera on the screen. Before I painted my truck I cut the dash and flattened the indentations where the radio knobs used to go, I also filled with my MIG the slight hole edge left from the holes the knobs went through on each side. To fit the screen I had to remove the face of my ashtray and mount a new one I made out of a piece of aluminum, I anodized it black, I am thinking of painting it to match the cab but I'm not sure yet. |
11-15-2010, 11:46 PM | #7 |
Re: Radios!
Hey Airspeed what is the name or part number on the deck? looks pretty sweet!
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers 1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles 1956 Ford F-100 Longbed with Original 272 and 3OTT 1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller) 1997 Dodge 3/4 ECLB V10 (MPG machine) |
11-16-2010, 12:03 AM | #8 | |
Re: Radios!
Here is a link http://www.soundstormlab.com/main/761 I bought it from mobileaudioandmore.com For a cheap model its built pretty good. It also has a touch screen that makes adjusting things easy without looking at it. The only thing I dont like is the remote, it came with one of those card shaped remotes with the little bubble buttons. Other than that it has performed great and actually sounds very nice! Last edited by AirSpeed; 11-16-2010 at 12:18 AM. Reason: forgot |
11-16-2010, 12:08 AM | #9 |
Re: Radios!
yea my friend has a sony that came with one of those tiny little remote things. its handy if your a midget or small handed . was there much of a modification you had to do to make it fit?
11-16-2010, 12:16 AM | #10 |
Re: Radios!
Its a single DIN so it fit right in my dash. Like I said I did have to remove the ashtray face and make a new one that wasn't as tall, the ashtray wouldnt open as it would hit the screen. The screen is motorized, it moves out of the way to insert a DVD, CD or memory card, it also tilts up and down so you can adjust the viewing angle. My wife actually watched a movie on it last week on a short road trip. It has a very nice picture!
11-16-2010, 12:34 AM | #11 |
Re: Radios!
okay thank you so it is kind of two parts the radio and then the faceplate?
11-16-2010, 12:55 AM | #12 |
Re: Radios!
It's one unit, the face plate, display is always visible, it doesnt slide into the deck when you turn it off like other models do, that is why I bought it, the ones that slide out always fold up and hit the dash pad in our trucks, that makes the screen angle down so you cant see it, the one I bought is always visible.
11-16-2010, 06:06 PM | #13 |
Re: Radios!
11-16-2010, 08:27 PM | #14 | |
Re: Radios!
11-16-2010, 08:28 PM | #15 | |
Re: Radios!
11-16-2010, 08:43 PM | #16 |
Re: Radios!
I only cut the dash to fit a single DIN head unit, any standard CD head unit fits the hole you see in the pic. All I cut was the sides of the original hole, the two holes where the stock radio knobs went through. After I cut it to size there was still the very edge of the original knob holes left and the indented area around them, I flattened those and welded up what was left of the edge of the holes. ( if that makes sense!)
If I take that DVD head unit out a standard cd player will fit in the same hole perfectly. Posted via Mobile Device |
11-16-2010, 08:55 PM | #17 |
Re: Radios!
Here is a pic of the hole after I cut it to size and welded up the little edge of the hole that was left over from where the original knob holes were.
Posted via Mobile Device Posted via Mobile Device Here is a pic after I first cut it, you can see the little left over hole that was on each end, these were also indented a little as well, I flattened the area with a c clamp then filled the edge with my MIG so that little hole wouldn't show up on the edge of the cd player. Last edited by AirSpeed; 11-16-2010 at 09:03 PM. Reason: Added pic |
11-16-2010, 09:09 PM | #18 | |
Re: Radios!
11-16-2010, 09:55 PM | #19 |
Registered Chevy Owner
Re: Radios!
I think I'm gonna put this old thing in.
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 Last edited by nickp51chevy; 11-16-2010 at 09:57 PM. |
11-16-2010, 11:09 PM | #20 |
Re: Radios!
nickp51chevy would you or anybody out there know if chevy had AM-FM 8 Track Player all in one ? The reason I ask is I found one like your AM-FM but with a 8 track player built in in a junked 67 panel. duramax 4 sorry for jumping in. Thanks all NGN
11-17-2010, 01:11 PM | #21 |
Re: Radios!
here is what i had done to my factory am fm. I wanted to stay 60's era so i had a early corvette amp modified to work with my am fm and now it is stereo. the little red light shines when i have a stereo station tuned in. the 8 track is only mono.
11-17-2010, 01:33 PM | #22 |
Re: Radios!
^^^^^NICE! Where did you find that amp?
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
11-17-2010, 02:42 PM | #23 |
Re: Radios!
The amp was supplied by the place i had the conversion done. i only had the radio and tape player.
11-17-2010, 07:13 PM | #24 |
Re: Radios!
Haha love it! i like the retro!
11-17-2010, 07:14 PM | #25 |
Re: Radios!
[QUOTE=NGN;4298720]nickp51chevy would you or anybody out there know if chevy had AM-FM 8 Track Player all in one ? The reason I ask is I found one like your AM-FM but with a 8 track player built in in a junked 67 panel. duramax 4 sorry for jumping in. Thanks all NGN[/QUO
hey man i dont care! im doin the same thing your doing, trying to find new stuff!
Thread Tools | |
Display Modes | |
