Old 11-16-2010, 10:13 PM   #1
pitbull784
trailing arm differences
I was wondering if there were any differences in trailing arm length between long and short beds
pitbull784 is offline   Reply With Quote
Old 11-16-2010, 10:24 PM   #2
cheyenne shortstep
cheyenne shortstep's Avatar
Re: trailing arm differences
ALL trailing arms are equal in length and interchangeable.
cheyenne shortstep is offline   Reply With Quote
Old 11-17-2010, 12:52 AM   #3
pitbull784
thank you
Old 11-17-2010, 05:37 AM   #4
coggonobrien
the only differance is between 1/2 and 3/4, 3/4 just had some extra sheet metal tacked to it.
coggonobrien is offline   Reply With Quote
Old 11-17-2010, 06:44 AM   #5
FL71C10
Where do you get new bushings, and how hard are they to change?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 11-17-2010, 09:57 AM   #6
Hart_Rod
Hart_Rod's Avatar
You can get the bushings at about any Chevy parts dealer. I got mine from Early Classic Enterprises (poly). As far as changing them out, the best way to get the old ones out is to burn them out. The new ones just push back in.
Hart_Rod is offline   Reply With Quote
Old 11-17-2010, 10:09 AM   #7
ERASER5
ERASER5's Avatar
I don't have an oxy torch, so I use the drill method. I drill into the rubber part with a 3/8" or 1/2" drill depending on what bushing. Several passes, side loading the drill many times. After a while most of the bushing will be in a pile of rubber chunks. Then go after the steel shell if there is one. There is less clean up, and no fire runs. ( I nearly lit up the garage when grinder sparks found some steel wool on the bench a few months ago. )
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 11-17-2010, 01:42 PM   #8
tubbedII
needs more $$$
tubbedII's Avatar
When doing new bushings on the arms, are a poly type better than rubber?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 11-17-2010, 01:45 PM   #9
Hart_Rod
Hart_Rod's Avatar
I think so. You get better performance out of the polys....
Old 11-17-2010, 01:47 PM   #10
cam.man67
cam.man67's Avatar
I just got a new set of trailing arms from Early Classics with rubber bushings. The way I understand it, rubber has more "give" and allows more flex in the rear. Good for comfort, maybe not so much for handling.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 11-17-2010, 04:08 PM   #11
tubbedII
needs more $$$
tubbedII's Avatar
Sounds good. I ask because when going over some bumps at a decent speed, it feels as if the rear shimmy's a little. It's got the extended panhard bar on it, so I don't think the rear itself is shifting, but I was hoping poly bushings would help this.
1970 2wd Blazer
Old 11-17-2010, 07:12 PM   #12
scrapmetalart
Junior Member
do you have a front stabalizer bar (sway bar)? it will help eliminate some of that feel
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 11-17-2010, 07:43 PM   #13
tubbedII
needs more $$$
tubbedII's Avatar
Nope...I sure don't. It astonishes me that this is true though because it's definitely my tail end that shimmys. I do plan on a front bar in the future, but still waiting on what I decide for the lower ca's before I take that plunge.
1970 2wd Blazer
Old 11-17-2010, 10:54 PM   #14
scrapmetalart
Junior Member
I just added a sway bar to the front of my 67 longbed & it definatley helped with that. It felt like the rearend side stepped after hitting bumps before. That stopped after I added the front bar. I put 1 1/4" in from a 1984.
Even with the stock used rubber bushings it is a HUGE improvement & my trailing arm bushings are stock & need replaced...
The sway bar was the best $50 I have spent lately for my truck.
Old 11-17-2010, 11:03 PM   #15
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
for those with a big bench vise or their own press....but w/o a torch...I just put mine in the press and pressed the old bushings out of the shell...and then new ones back in.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-19-2010, 05:23 PM   #16
Fitz
Sway bar in front resolves about 80 % of the bump steer. When I added a sway bar in the rear and polyurethane bushings in the trailing arms it cured the rest. There is an optimum setting for an ECE super track bar and you will need to mess with it a bit before everything is just right.
Fitz is offline   Reply With Quote
Old 11-19-2010, 05:26 PM   #17
Hart_Rod
Hart_Rod's Avatar
Interesting. Is it something other than just centering the wheels between the wheel wells?
Thread Tools
Display Modes
