Old 11-21-2010, 12:07 PM   #1
Touchdown67
Touchdown67's Avatar
seam sealer?
I am repainting my 65 C10 fleet side and the question is when should you put seam sealer down? Before or after paint? I'm talking about the gaps between the rear wheel tubs and the bed sides, and the drip rail on the top of the cab and all other spots. The truck is going to be painted in the 2 tone fawn beige and ivory white combination. Thanks for any help
Touchdown67 is offline   Reply With Quote
Old 11-21-2010, 01:25 PM   #2
oem4me
Re: seam sealer?
I'm not sure if the same product should be used in all applications, but I would think prime, seal, prime, then paint makes sense for most. Anybody disagree?
Old 11-21-2010, 05:47 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Re: seam sealer?
You may find some valuable information in this tech article:
http://www.autobodystore.com/seamsealer.shtml
Here’s the original information in a forum thread with further member discussion. Although the search words have highlight blocks over them, if you drag your curser over the paragraph all the words appear clearly:
http://autobodystore.com/forum/showt...ht=seam+sealer
For the roof of my truck, I used the Evercoat Maxim self-leveling sealer shown in the last response. When I did mine I filled the sides and front of the gutter clear to the top where possible. This way the way the water just runs off instead of sitting in a channel with no way to drain. The nice part is it can be applied with a standard caulking gun. Many of the professional grade sealants require an expensive specialized application gun. Here's how it looks on mine:
Here are a couple of links pertaining to this product:
http://www.evercoat.com/productDetail.aspx?pID=257
http://autobodystore.net/Merchant2/m...gory_Code=JASS
You’ll need something that is not “self-leveling” for the fenderwells. It looks like the Quick N Firm may be a good choice. Here’s a link to Evercoat’s other sealers, although there are other quality brands available. I've just had good luck with Evercoat products:
http://www.evercoat.com/productCategory.aspx?cat=41
Old 11-21-2010, 06:32 PM   #4
iiizman
iiizman's Avatar
Re: seam sealer?
I looked at Alan's build and saw he used evercoat and so far everything I have bought that is made by them is great.
Bad Decisions usually make for Good Stories.
iiizman is offline   Reply With Quote
Old 11-22-2010, 07:46 PM   #5
kirtzen
kirtzen's Avatar
Re: seam sealer?
First you would use an epoxy primer. Then I would use fuser paintable seam sealer. You can get it at any autobody supply store. You can use any caulking gun "no special gun needed". Then, when the seam sealer is completely dry I would shoot high build primer over the sealer. Then sand it with 600 grit wet. This makes it smooth as can be. Then use a primer sealer and paint away. Fuser is much cheaper the evercoat. I have found that self leveling sealers can be a pain on seams that are vertical.
kirtzen is offline   Reply With Quote
Old 11-22-2010, 09:43 PM   #6
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: seam sealer?
go to your local automotive paint store get some paintable seam sealer that you can squeeze from a regular caulking gun. this stuff goes right over primer or sealer let it cure before you paint and you're good.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 11-22-2010, 11:24 PM   #7
Touchdown67
Re: seam sealer?
Thanks for all the good help...
Thread Tools
Display Modes
