Old 11-24-2010, 10:01 AM   #1
fortytwo
67 to 72 3/4 ton lower a-arms are they the same?
Hello,
I am looking for some a-arms to lift my c10 with but i need to know what years are the same as 67. I have 2 wanted to buy messages to people parting out trucks but without this i cant buy.
Ed
fortytwo is offline   Reply With Quote
Old 11-24-2010, 11:36 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 67 to 72 3/4 ton lower a-arms are they the same?
You can use 3/4 ton arms from 67-72 or 73-87.
The 73-87 version have the rubber bushed cross shafts, the 67-72 have the steel bushings just like your 1/2 ton arms.
(3/4 ton balljoint hole, in the arm, is bigger than the 1/2 ton version)
Keith
Convert to disc brakes.
Old 11-24-2010, 12:05 PM   #3
fortytwo
Thanks!!,
So i take it the 88-98 upper ball joint is the same as my 67 c10 and the lower arm is to fit the larger lower one.
Old 11-24-2010, 12:10 PM   #4
lolife99
lolife99's Avatar
Originally Posted by fortytwo View Post
Thanks!!,
From what I understand,... you can bolt the 88-98 upper balljoint into your c10 upper a-arm.
And you will need a C20 (3/4 ton) lower a-arm to use the 88-98 lower ball joint.
I have never done this myself,...
This is info provided by other members here on the board.
Keith
Old 11-24-2010, 12:32 PM   #5
Mr.C
Mr.C's Avatar
Hey Fourtytwo, I am planning on pulling the uppers and lowers off of my CST/20 in a week or so. Let me know if you want them.
How about you go over and introduce yourself, build me up, that way I don't have to brag about myself later.
Mr.C is offline   Reply With Quote
Old 11-24-2010, 03:34 PM   #6
fortytwo
lolife99,
Thanks a bunch.
Mr.C
pm sent
Thread Tools
Display Modes
