Test a relay fuse????
I have a 2001 sub and the headlight just quit this morn. Can you test the HDLP relay fuse? All else is working fine. The only fuse I find for headlamps is the relay and just to the right a 15a for r and l hdlp. All of these under the hood in the box. Any help? Gary
One day...
Re: Test a relay fuse????
I know is sounds like a stupid question but did you check the bulb also?
![]() Join Date: Sep 2005
pull the fuse and see if it is blown. do the high beams work or did both good out? have you check teh bulbs? i always recommend replacing headlights in pairs because they both run the same amount of time and tend to go out around the same time
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Thread Tools | |
Display Modes | |
