Old 12-05-2010, 10:16 AM   #1
dodgiesdad
dodgiesdad's Avatar
lift for a factory 65 4X4
I have a 65 K-10 short bed. It is sitting on the original springs, but has newer axles front and rear (best I can tell out of a 71 Blazer). The factory springs are very tired, I am hoping to redo the suspension in the spring. I would like to get 2-3 more inches out of it. Short of custom springs has anyone found springs from something else that bolt in and get this, or add-a-leafs? Any ideas would be appreciated. I am currently running 33"s but would like to get to 35"s, but more importantly get the right stance.
dodgiesdad is offline   Reply With Quote
Old 12-05-2010, 03:23 PM   #2
raycow
Re: lift for a factory 65 4X4
It looks higher than stock to me. Are you sure you don't already have some kind of lift on it now?
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 12-05-2010, 07:11 PM   #3
dodgiesdad
dodgiesdad's Avatar
I bought it as you see it in the picture, I have added a bench seat from a late model, and replaced all the brakes. Other than that I am not certain of anything. The front springs are flat, and have 5 leaves in the pack. The rear are very stiff, have a small arch and 7 leaves.
Old 12-06-2010, 08:57 AM   #4
They sat pretty high stock.I don't think anyone makes an off the shelf lift for pre-69s with the wider leafs.It's an original 4wd with newer axles,right?A spring shop can do whatever you want.i had a '90 Blazer I didn't want to lift,just bring the front up to level and give room for 12.50/33s on 10" wheels.They arched and added a leaf to whatever height I wanted.Not expensive,especially when you figure labor.
Old 12-06-2010, 04:52 PM   #5
royo
royo's Avatar
Could you just measure Eye to eye on the springs and find some replacements that way. I think on the rear of a half ton the springs are 52in and on a 3\4 they are 56in Dont hold me to this . lol
nickle and dime
royo is offline   Reply With Quote
Old 12-07-2010, 06:33 AM   #6
dodgiesdad
dodgiesdad's Avatar
Thanks for the responses. I have the spring measurements and will be checking them on other trucks once it warms up here. Short of that I will be visiting a spring shop in the spring, unfortunately I do not really have a local one.
Old 12-07-2010, 11:26 PM   #7
Raider Rudy
Raider Rudy's Avatar
That is a great truck! I'm real envious! I wish I had it
1969 Chevy Long Fleet Custom C/10 (2nd owner)
1971 Chevy Short Fleet Custom C/10 (2nd owner)
2001 Chevy Silverado Ext Cab
Raider Rudy is offline   Reply With Quote
Old 12-08-2010, 06:29 AM   #8
dodgiesdad
dodgiesdad's Avatar
Thanks, its good 20 footer, and a blast to drive. It will be a great truck once I get done redoing it. Working on mechanicals now, and hopefully do the body next year.
Old 12-10-2010, 10:51 PM   #9
Raider Rudy
I just put a picture of your truck on my screen saver
Old 12-10-2010, 10:59 PM   #10
k14burb
k14burb's Avatar
I had a similiar delima with my '66 burb. The PO had 2.5" lift blocks on the front so the diff wouldn't hit the big block oil pan it has. I found that no springs were available so I had a local spring shop do it right. Got about 1/2" more and swapped the old rotten 35's for 37's. I still have to do the rear though, it's got a 3/4" block on top of the factory block.
Here's the 35's with the blocks
And the 37's with 3" springs
‘66 Suburban 4x4 LQ4/4L80e Dana 60’s
‘67 Camaro RS/SS convertible 350/700r4
‘74 K10 Stepside 402/TH350
k14burb is offline   Reply With Quote
Old 12-10-2010, 11:30 PM   #11
McC_65_91
McC_65_91's Avatar
id be interested in this as well, i got a 65 as well but GMC, so leafs all around (dunno if chevy vs GMC had a difference in ride height but probably not), mines on 33's and half ton like urs
heres how it sits now for comparison if u think urs could possibly have had a lift done by PO. mines stock height for 33s to my knowledge but it does look dam high
McC_65_91 is offline   Reply With Quote
Old 12-12-2010, 02:56 PM   #12
dodgiesdad
dodgiesdad's Avatar
Definitely no lift on my ride, yet. I sits the same as yours. I do have some clearance problems with the front axle and the exhaust thanks to the work the PO did (apparently he only drove on flat paved roads). I need to fix the clearance issues, would like to even out the truck and gain a little more height. If I can do all with the same modification that would be great. I don't plan on hauling much with this has anyone done something to improve the ride on these or soften it up some?
Old 12-12-2010, 03:26 PM   #13
lakeroadster
Originally Posted by k14burb View Post
Gourgeous 'burb!
lakeroadster is offline   Reply With Quote
Thread Tools
Display Modes
