Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-05-2010, 11:26 PM   #1
kaycee
kaycee's Avatar
Th-350 shifting
Hey I got a TH-350 with a B&M shift kit 2K stall it shifts real early from 1st to 2nd like around 1200RPM'S then it seems to hold in 2nd for a long time before it hit's second.This happens when I mash the gas ,it performs good when driving normal except it still shifts to early this has done it since I first got the trans.I have allso tried to adjust the vacum modulator but seems there is no improvement or change new modulator was installed and still no effect.Now I have turned the screw like a bazillon times each way in/out.How can I find out where this needs to be so I can start from scratch?What is causing the shifting problem? Thanks for the info
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 12-05-2010, 11:37 PM   #2
fattyarbuckle
Re: Th-350 shifting
sounds like a govenor issue...is this a rebuilt trans in stock aplication?
fattyarbuckle is offline   Reply With Quote
Old 12-06-2010, 12:33 AM   #3
kaycee
kaycee's Avatar
Re: Th-350 shifting
HHMMM NO it's in my 69 C-10 I don't think it has been rebuilt,the trans works great on a basic drive to the store and back or highway cruise except that it shifts to soon 1 to 2nd.But when I get on it it hangs in second to long before going into third.I was wondering if it could be the governor
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 12-27-2010, 10:36 PM   #4
orbot
orbot's Avatar
Re: Th-350 shifting
interested in what it is as well.
orbot is offline   Reply With Quote
Old 12-27-2010, 11:17 PM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Th-350 shifting
The modulator is only 1/2 of it. Adjust the kick down cable (check any chiltons for the proper adjustment) and if it still does an early 1-2,, then it's time to dig into the governor like mentioned
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Thread Tools
Display Modes
