Old 12-06-2010, 05:30 PM   #1
troy54gmc
troy54gmc's Avatar
boxing my 54's rear frame
Ok guys i got alot done this weekend. got all tubing cut, cleaned, measured and tacked together. wow what alot of measuring to get every angle just right. then attaching to old frame and making it square and perfect. took me about 16 hours. now i just have to final weld it and im gonna add some fish plates to the joints for extra strenghth. next is the 4 link and air bags. let me know what you think....
troy54gmc is offline   Reply With Quote
Old 12-06-2010, 06:14 PM   #2
Fat Mike
Fat Mike's Avatar
Re: boxing my 54's rear frame
Can you show a close up of the front part of the c-notch where it ties into the frame? What size is the metal tubing that you used. It looks very nice!
Fat Mike is offline   Reply With Quote
Old 12-06-2010, 06:43 PM   #3
troy54gmc
troy54gmc's Avatar
Hey thanks Mike. i used 2x6-3/16" square tubing for the frame. im at work now and i dont have a close up picture of where i joined the frames. i will snap a picture when i get home in the morning and post it for you.
Old 12-06-2010, 06:49 PM   #4
troy54gmc
troy54gmc's Avatar
hers what i started with.
Old 12-06-2010, 08:31 PM   #5
BigJock
Looks good,
I guess you'll be layin' those running boards on the pavement when you're done!
Keep up the good work.
BigJock is offline   Reply With Quote
Old 12-06-2010, 08:38 PM   #6
Kabwe
Certified Car Nut
Kabwe's Avatar
Looks good, nice work.
Kabwe is offline   Reply With Quote
Old 12-06-2010, 09:12 PM   #7
52 Rat
52 Rat's Avatar
Nice work! This is something like what I want to do to the rear of the 52. I can't decide on a four link or trailing arms with bags.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 12-07-2010, 01:45 AM   #8
FnLow69
FnLow69's Avatar
looks good, just curouis why you choose 2x6 instead of 2x4?
FnLow69 is offline   Reply With Quote
Old 12-07-2010, 02:19 PM   #9
troy54gmc
troy54gmc's Avatar
hey guys thanks for nice comments. mike here are the pictures of where i joined frames. sorry there not that clear i had to take them with my phone cam. what i did was cut the original frame just behind the rear mount for the running boards. i cut the top and bottom off and left about a 5 inch piece of the side original frame to tuck inside new frame for alignment and welding to. the reason i went with 2x6 tubing over 2x4 is to match up with the original frame. i plan on boxing entire frame and want everything to be the right proportion. i also got a smokin deal on the steel, 20' stick for $60 bucks. the notch end up being almost 12" so yes i hope with 22" wheels i should be close to laying frame.
Old 12-07-2010, 02:37 PM   #10
Kim57
Kim57's Avatar
looks good.
Kim
Kim57 is offline   Reply With Quote
Thread Tools
Display Modes
