Old 12-06-2010, 10:11 PM   #1
akpackfan
Snow driving in a C10
Ok, lots of winter up here and it's real hard to hold out till spring to drive my C10. What wheel and tire combos are you guys in snow country running to drive your 2wd's in winter? I assume the skinnier the wheel the better. We can run studded tires up here so that is probably the best bet. How much weight are you putting in the bed? Any input would be appreciated......
akpackfan is offline   Reply With Quote
Old 12-07-2010, 04:57 AM   #2
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Re: Snow driving in a C10
I have a 71 4x4 c10 with 33x12.5x15's. I had it all set up for snow with a complete engine core strapped over the rear axle and 4 5gallon buckets of dry sand. Plus a set of chains to get up my 14 % grade road.
But as luck had its way I got stuck at work with my car for 4 days.
oldiron is offline   Reply With Quote
Old 12-07-2010, 08:16 AM   #3
cam.man67
cam.man67's Avatar
Interested in this, too. We may not get the snow you guys do in more northern regions, but there's a lot of slush.
I've got a bunch of concrete blocks, think I just fill the bed with them.
What kind of chains do you guys use?
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 12-07-2010, 09:29 AM   #4
coloradosean2009
coloradosean2009's Avatar
I run 235/75/r16 with a set of Yokahama Geolander AT. The weight is provided by three tubs of sand. Here is a thread I started last year about my weight setup. This year I replaced the tubs and spent only $10. http://67-72chevytrucks.com/vboard/s...d.php?t=366756
The sand is a real bonus if you get stuck in an icy parking lot.
__________________________________________
Sean
1972 C20
2005 4Runner
coloradosean2009 is offline   Reply With Quote
Old 12-07-2010, 09:34 AM   #5
longhorn396
S.D.M.F.
longhorn396's Avatar
I run 285/75r16's on the back of my longhorn. there mastercraft m/t's and they do good
1969 Chevy Longhorn 396/400 3/4 ton.
1991 Chevy Camaro RS 305/700r4
1978 Honda XL175 and XL350(the evil twin)
2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous
1971 BSA Thunderbolt 650cc
longhorn396 is offline   Reply With Quote
Old 12-07-2010, 11:09 AM   #6
70cst
70cst's Avatar
I would offer suggestions but my truck is alergic to snow. Good thread.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-07-2010, 11:16 AM   #7
sixtyeightchevykid
sixtyeightchevykid's Avatar
this will be the first winter that my truck will go thru since i have gotten it, but whith my other truck (1992 s10 manual trans) i just put in concrete blocks and run a strap thru the holes and keep them tied down. and i put a 5gal bucket full of wood ashes, they work just as good as sand and plenty of ashes when the house is heated with wood, and i throw in a shovel just in case..
sixtyeightchevykid is offline   Reply With Quote
Old 12-07-2010, 11:22 AM   #8
Lee H
Lee H's Avatar
When I lived in snow country I used skinny (225 x 15) snow (not all weather) tires and had a few hundred pounds of sand bags in the rear of the bed with a 2x6 across to keep them some what in place.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-07-2010, 11:26 AM   #9
Alex Hayley
Looking at my signature it might seem I should not know anything about driving on snow and ice but I have spent most of my life in a cold, snowy area of Canada. Tire selection is different between ice and snow. Snow requires a narrower tire so the tire does not float on the snow. Ice likes a wider tire with more surface area for the tire to contact.
Weight in the back is always good. Use sand backs. Avoid hard blocks. If you end up a panic slide (which is possible in snow and ice of course) and hit someone from behind, the hard blocks could break free and become a real hazard for the passengers. What I used to do is not clear the snow out of the bed and it would provide the weight needed.
Alex Hayley is offline   Reply With Quote
Old 12-07-2010, 02:29 PM   #10
68350
68350's Avatar
I drove a 68 gmc 1/2 ton throughout high school and never had any real problems. It had a posi which can help or hurt, depending on the situation. I just threw a few hundred pounds of sand bags over the rear axle and that was all I ever needed. On my 02 GMC(4x4), I bought a set of chains for the mountains from wal-mart and they have yet to fail me. If I had a choice of tires for snow/ice, I would go with BFG All-Terrains, they are the best tire I have had in the snow, although my cooper s/t and uniroyal liberators have not given me any problems yet(both were on 4wds but I can cruise around in town in 2wd).
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 12-07-2010, 03:40 PM   #11
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
ummm, what is this "snow" you are speaking of? JK, we had 12" last February and my truck did very well in the garage, no slipping what so ever. These people here are nuts when it snows or ices here in Texas.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-07-2010, 04:34 PM   #12
DW67c10
DW67c10's Avatar
Good winter tires work wonders!
http://www.tirerack.com/tires/tires....e+UV&code=yes&
DW67c10 is offline   Reply With Quote
Old 12-07-2010, 05:02 PM   #13
jakeblues652
jakeblues652's Avatar
alaska with a 2 wheel drive? you have more nuts then id ever have. i wouldnt drive a 2 wheel drive in pa snow.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 12-07-2010, 05:44 PM   #14
78cheyenne292
your aslmost worst off in a 4 wheel drive.. yah you can get yourself unstuck and make it through some deep stuff.. but if you loose traction with all 4 tires your real screwed.. take it from a canadian.. 2wd does just fine in the snow.. iv been lovin this last week of winter driving..
78cheyenne292 is offline   Reply With Quote
Old 12-07-2010, 06:04 PM   #15
jakeblues652
oh yeah, 2 wheel drive will go alright in snow, but i like my insurance policy when i get get stuck in 2....just pull the lever turn the hubs and off you go.
Old 12-07-2010, 08:11 PM   #16
cam.man67
cam.man67's Avatar
I'm not planning on getting a set of tires until spring, do you guys think my Dunlop Radial Rovers will be ok, provided enough weight in the bed and all that?
Old 12-07-2010, 08:30 PM   #17
Rob H.
Rob H.'s Avatar
I haven't got my truck on the road yet but around here growing up everybody had 2wd's (4x4 was just an over rated unneeded option to the old timers here LOL). In the winter of 1977-78 when we were buried here by a blizzard and had 3 ft. of snow on the ground, Dad had a 70 C/20 with a 307 and 4 speed. They had ran bulldozers on the roads too open them but were still packed with snow and ice. At that time he had a set of 700-15 mud and snows and chains and about half a load of firewood. That truck went like a tank the whole time. BFG all terrains would be great I think or a set of Mastercraft mud and snows. A couple of inner tubes cut and filled with sand will give ya some weight and a set of tire chains for when it's really bad, you shouldn't have any trouble.
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline   Reply With Quote
Old 12-07-2010, 11:10 PM   #18
jakeblues652
around here, you're considered a fool without a good 4x4 pickup in the winter. and you always know if the roads are in fact bad enough where you need 4 wheel, that means you're using it to pull the city folk out of the ditch every half a mile.
Old 12-08-2010, 09:10 AM   #19
cam.man67
cam.man67's Avatar
Regarding weight, I've got several truckloads of concrete block at the farm that I was thinking if using to weigh down the back. Is this an ok medium to do so with? I plan on covering the entire bed with one layer block, then running tie downs overtop to keep them in place. Does that sound like an ok idea?
Old 12-08-2010, 11:14 AM   #20
Rob H.
Rob H.'s Avatar
I used to use concrete blocks till a few years ago. There was a guy that was killed when he got in a slight accident. The truck could have been driven home, but the blocks in the bed came through the back glass and caved his head in. I wouldn't do it again without a well built headache rack and not sure then. Also, aside from the danger, they constantly vibrate and eat the paint off the bed and wear the metal.
Rob
48 Willys CJ2A
Old 12-09-2010, 01:37 PM   #21
LilD
LilD's Avatar
Back in the late 80s I had a 69 with ordinary truck tires that went through the snow just fine. I never added weight and so far my 70 I have now has done the same.
LilD is offline   Reply With Quote
Old 12-09-2010, 01:45 PM   #22
timjt
You aren't kidding! Driving on highway 635 or the high 5 is suicide when its just icy, and when it snows watch out! People think because the road doesnt have black ice on it you can drive like normal on 2 inches of snow!
2001 silverado stolen by family
1983 short n wide custom deluxe SOLD
1985 silverado longbed 305 engine 700r4
OH NO! NOT ANOTHER LEARNING EXPERIENCE!!!
"Just because you can do it, doesn't mean that you should"
timjt is offline   Reply With Quote
Old 12-09-2010, 02:05 PM   #23
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I couldn't imagine driving my truck in the snow, it won't hook at all in the rain. Even when slightly wet out I can't go over half throttle in 4th gear or its sideways. Even here in sunny Cali I have some snow driving experience (most of it in a 2wd ford ranger) and I say concrete blocks are a bad idea, I've used sand or firewood with good results. I've learned always carry a shovel, if you get stuck start shoveling yourself out and put all the snow in the bed for extra weight. Also if you keep a bag of kitty litter in the truck it works great for throwing down for traction in ice. I had a set of the liberator A/T's and they worked great, great price too. The only problem with them is they take a lot of weight to balance, I had one of my 31x10.50x15's that took 15 oz. of wheel weights to balance out. The tire shop ordered me another one, and that one balanced much better.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Thread Tools
Display Modes
