Old 12-08-2010, 03:08 PM   #1
GobbleStalker
GobbleStalker Calls
GobbleStalker's Avatar
Powder coat or paint.
So I am just getting ready to frame off the truck next month and am debating to either sandblast and paint the frame or sandblast and powdercoat the frame. Anyone have experience with the good and bad of each option.
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino.
Stay Tuned!
1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD!
09 GMC Sierra SLT All Terrain pkg.
2014 Jeep Wrangler Sahara unlimited. ( The wifes ride )
GobbleStalker is offline   Reply With Quote
Old 12-08-2010, 03:21 PM   #2
GmcSS
GmcSS's Avatar
Re: Powder coat or paint.
I asked the same question when I started my frame off. The response was Paint it yourself unless you plan on it being a trailer Queen. I use Por-15 on the frame after sandblasting, It came out great and went on easy. I would do it again.
GmcSS is offline   Reply With Quote
Old 12-08-2010, 03:32 PM   #3
Southcity
Southcity's Avatar
GMcss has a good point but I have also heard other opinions about both methods and I am sure others will chime in about this:
Powder Coat: Looks great, durable, long lasting BUT, difficult to touch up and can trap moisture and rust if they should develop
Paint: Looks great, can be durable and long lasting depending on what you use (POR15 is one option) you can do it yourself and it is much easier to touch up
Hope this helps
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 12-08-2010, 03:36 PM   #4
OARNGESI
OARNGESI's Avatar
I got some bumpers done they left looking like a 40 year old bumper should and came back as if i ordered a new piece if i had payed my self $10 an hour to strip and paint them myself plus quality supplies i would probally have even more in them the frame on my truck is painted but the frame on my next one will be powdercoated easy
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 12-08-2010, 03:56 PM   #5
Valhalla
Valhalla's Avatar
I am in the same boat now. I have a local place that will blast and powdercoat the frame for 350 or 500 if I want a crazy color or hammertone powder. The POR 15 is very nice stuff as well and easy to touch up. Powder coating is nice and is durable but has its downfalls such as possible chipping/rust build up with no ability to touch up. I am still debating whether I want to paint with POR 15 or Powdercoat myself.
I don't know how much por 15 I would need but the ability to touch up is definitely a plus. And it also inhibits rust from forming.
My build thread for Project TiC TaC/Jazzmin Oh Yeahhh
Cheap work is never good and good work is never cheap. Lesson = learn to do it all the right way on your own.
SqueegeeMan
Valhalla is offline   Reply With Quote
Old 12-08-2010, 04:04 PM   #6
GobbleStalker
GobbleStalker Calls
I have heard the por15 also has issues with moisture buildup behind it? I was also thinking of painting the frame with a single stage black at one point. Could you not touch up a powder coated frame with paint though?
Kev
Stay Tuned!
Old 12-08-2010, 04:06 PM   #7
smn69
1 quart should do the job.
smn69 is offline   Reply With Quote
Old 12-08-2010, 04:43 PM   #8
SATownChevy
SATownChevy's Avatar
i used this on my frame
before
after
View pics of my truck - 1968 Chevy C10 SWB - Photobucket
I'm not wasting money on my truck, I'm helping to rescue the economy one mod at a time.
SATownChevy is offline   Reply With Quote
Old 12-08-2010, 05:16 PM   #9
yote1234
yote1234's Avatar
i made a deal with my powdercoater... one price for every part that needed blasting and powdercoating on the whole truck,brackets,frame,springs,core support,peddals...every thing!!! it cost alot but im very happy with the outcome..and it will last for??? a very long time!.very happy!
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 12-08-2010, 06:22 PM   #10
DANTIP
DANTIP's Avatar
Not to complicate things, but I prefer have some things EPOXY powder coated like battery tray/support, core support, etc. This coating is very resistant to chemical attack and subsequent rusting. If it not chipped, it will look great basically forever. I think polyesters and acrylics are used for parts exposed to routine sunlight. Another consideration is electrical grounding. If your frame is powder coated, you must scrape the coating off below the grounding straps.
DANTIP is offline   Reply With Quote
Old 12-08-2010, 09:48 PM   #11
1970 CST STEP
i am in the same boat on what to do! i know powdercoat is more durable IF APPLIED CORRECTLY! this is the part that scares me, how long down the road do you get before you find out? i did a LWB with a product called DP90, that was almost 20 yrs. ago and still looks good, but has a dull like finish, have no idea if it even exists anymore!! i think i am leaning towards POR15???
1967 SWB (small window) original
1970 4x4 STEP
1970 CST SWB FLEET
1972 SWB FLEET ORIGINAL
1970 CST STEP is offline   Reply With Quote
Old 12-08-2010, 10:57 PM   #12
VA72C10
VA72C10
VA72C10's Avatar
I have heard that there is a way to mix something to touch up powder, but I just wouldn't trust it for anything other than a trailer queen. What do you do at all the ground points, where the lock washers scratch it, where the U-bolts scrape it? I imagine it will definitely scratch/chip there over time and lead to rust that will do nothing but spread
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-08-2010, 11:14 PM   #13
Nsanehotrodz
Nsanehotrodz's Avatar
Powder coating will show every imperfection on the frame. I would paint it if you want perfection. DeWayne
Nsanehotrodz is offline   Reply With Quote
Old 12-08-2010, 11:17 PM   #14
Mike Bradbury
Mike Bradbury's Avatar
I have a really good powder coat company here in San Diego, that upon request will zinc coat it first then powder coat it. They are very good at what they do and I have chipped some products and very little rust occurs under the coating. As far as the grounding goes you could weld a S.S. tab or bracket to the frame and have them tape it off so that you could bolt the ground strap to it. They also do sell a poly urethane touch up paint for most RAL colors. I have not used the Por 15 but I have used a lot of powder and I would do it all again on the next one. As far as rusting and finish is concerned, it is all in the prep. If you just take it down "as is", then is is going to look just the same only black and shiny. But just like preping for paint you have a lot of grinding and sanding to do first.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 12-08-2010, 11:21 PM   #15
leddzepp
Moderator
leddzepp's Avatar
Trailer queen = powder coat
Anything but a trailer queen = POR 15
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 12-10-2010, 10:07 AM   #16
GobbleStalker
GobbleStalker Calls
Thanks for the input guys. I am building a show truck but a driver also. I will think it over more the next month and eventuually have to make a decision.
Kev
Stay Tuned!
Old 12-10-2010, 11:12 AM   #17
BossHogg69
motor exploder
BossHogg69's Avatar
I recently was in the same situation - I ended up dressing my frame with a wire wheel on my grinder and had it painted by a local shop here that paints heavy equipment and semi-truck trailers. It turned out great and only cost $100 bucks in gloss black. I wanted to be able to touch it up easily and quickly if need be. I am very pleased with how it turned out.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 12-10-2010, 12:09 PM   #18
Mike Bradbury
Trailer Queen?? Really? Powder coating is what they do to dirt bike frames and industrial machinery to protect and prevent rust, it is what the industry has found works the best for the job. If done right will last years longer than paint with little to no maintenance. I wanted a truck that I could keep nice looking, but also be able to work on the brakes or the suspension with out looking like I just got out of a coal mine. I am a bit lazy when it comes to washing the truck every week, to be honest it has been about three months since I washed it. Nothing sticks to P.C. it is very easy to clean and keep clean. I just spray under the truck with the hose and wipe down. My truck is a Daily Driver but when I meet people who are interested in the truck they always like the neat, clean appearance of the undercarriage. If the powder is applied right then you will not have to worry about touch up because it's a lot tougher than regular paint.
Old 12-10-2010, 01:56 PM   #19
treveiger
treveiger's Avatar
So basically both have there ups and downs. If you drive on gravel roads or parts where rock chips are very common i would go with paint but if itll never see those conditions i would go with powdercoat.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 12-10-2010, 02:24 PM   #20
BearFlagRepublic
I had the privilege of my frame being blasted and powder coated by the PO. I can't say I have any complaints with it whatsoever, he had it done about 5 years ago and I don't see any issues or imperfections appearing at all. I am just happy it was done before I bought it!
BearFlagRepublic is offline   Reply With Quote
Old 12-10-2010, 02:27 PM   #21
cdowns
cdowns's Avatar
i like blasting then POR15 and when still tacky sspray with satin black enamel for finished project
Old 12-10-2010, 02:33 PM   #22
Allensracing
Allensracing's Avatar
a consideration for powdercoating..
if you ever plan to modify or weld the frame, or if you ever want the frame done again, or change color...
the powdercoating can be a real pain to remove.
yes, powdercoating can last for a lot of years. personally, I still have a 66 truck I bought in 1989. there are things I did to the truck when I first bought it and I assumed I would never need to do them again. guess what?
20 years after I replaced all my front suspension with moog parts, it is starting to get sloppy again.
if I powdercoat this year, how hard will it be to do it again in 25 years?
I prefer paint on my truck.
I will powdercoat my motorcycle
Allensracing is offline   Reply With Quote
Old 12-10-2010, 03:53 PM   #23
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
My Typhoon's frame is powdercoated, looks beautiful and is quite good still after 6 years. I have chipped and damaged it in places, and touched it up with a heavy duty epoxy and had no rust trouble.
That said, when I eventually strip the frame in my truck, it's getting galvanized and then most likely bedlined - a thick, rubberized coating.
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 12-10-2010, 04:42 PM   #24
ripper70
ripper70's Avatar
I used POR 15 on mine then coated over it with Chassiscoat Black from smae POR 15 company. They have epoxy coatings as well that are rock hard. Check out there web site www.por15.com.
ripper70 is offline   Reply With Quote
Old 12-10-2010, 06:24 PM   #25
chewychevy67
I used dupont self etching primer and POR -15 after having the frame blasted and i am very pleased. nice finish and easy to touch up. i've had to a couple times and can hardly tell where i did.
chewychevy67 is offline   Reply With Quote
Thread Tools
Display Modes
