How too ??
I have a 53 that I need some touch up paint mixed .The only piece I can think to remove to have scanned is the cowl vent .How difficult is this to do ?
All help appreciated Thanks Posted via Mobile Device
1955 Chevy 2 door Wagon 1967 Short Wide BAGGED Gone to someone else 1953 Shop truck Clipped and Snipped sold 1951 GMC Bagged and patina |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Re: How too ??
google 1953 chevy paint code.check out the stovebolt tech tip.there is a chart that gives you all the paint codes.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
![]() Join Date: Mar 2007
Re: How too ??
I should not be too difficult as long as you can access it easily from underneath the dash. If I remember correctly, there should just be small machine screws and nut that hold the hinge together. Unbolt from there and you should be able to lift it out.
Good luck
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
Re: How too ??
The truck is not a factory colour .thanks for the help .
Re: How too ??
Its not too hard to get the vent cowl out if you take it almost completely apart. If it has never been apart it may be difficult. I would suggest taking the whole truck to a body shop that has a scanner and see if they can help you out.
Thread Tools | |
Display Modes | |
